Would this be enough lift? >
Old 06-27-2006 | 09:48 AM
scottc's Avatar
Default Would this be enough lift?
It's a Formuls F402sr1 1984. Is a 12,500lb lift enought for this boat? Have gotten conflicting info. Formula says 9500lb dry, but is this real?
scottc is offline
Old 06-27-2006 | 09:53 AM
OldSchool's Avatar
Default Re: Would this be enough lift?
Ummm.....NO!!!
Get a minimum of a 15K or an 18K lift.
OldSchool is offline
Old 06-27-2006 | 11:41 AM
mjb
I have a '97 straight hull 38 Top Gun. It's a HEAVY boat but I'm guessing yours a little heavier. I have a 12500 lb lift. It is right on the edge. With full fuel, I have a hard time lifting the boat up real high as the wire spool gets bigger. I would think you should go for the 15,000 lb lift.
mjb is offline
Old 06-27-2006 | 11:54 AM
fund razor's Avatar
Sweet boat.
Is that the same one that GregP sold to InspectTed?
fund razor is offline
Old 06-27-2006 | 03:28 PM
Bill 3's Avatar
Can you pull the boat over a scale?
If the lift will be enough or not depends on how conservative the manufacturer is with their numbers.
Bill 3 is offline
Old Navy
Prop Talk
22
08-05-2008 04:24 PM
PARADOX
04-28-2008 11:30 AM
Magicfloat
09-26-2006 07:49 PM
itilldo
Fountain
6
02-02-2006 07:15 PM
timucin
1
10-22-2003 07:09 AM
