Procharger M3 >
Procharger M3
Procharger M3
Old 06-28-2006 | 07:10 AM
Default Procharger M3
Any one here running the m3's .If so have they been reliable.I know that the m1's are good units. When the m3 's came out the had problems with the seals blowing out.
baja27 is offline
Old 06-28-2006 | 12:48 PM
articfriends's Avatar
Default Re: Procharger M3
Ive got over 350 hours on a m-3sc,never been rebuilt or went bad,Smitty
articfriends is offline
Old 06-28-2006 | 11:17 PM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
good units.. Im probably not far from you in PA.. call me if you would like to know more. We are an authorized distributor & installer for them.. . Jamie / Lakeside
570-639-2628
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 06-29-2006 | 11:36 AM
Artic Friends How Pounds Of Boost Do You Run At ,what Fuel Presure
baja27 is offline
Old 07-09-2006 | 01:38 PM
9-10 psi of boost,70 psi fuel pressure with 63 lb injectors. I spoke too soon about the procharger,bearing went yesterday allowing impellor to grind into casing,my own fault though. I called procharger over winter and asked if I should be thinking about new bearings/getting unit rebuilt and they said it should easily run another 100 hours,should have had it done anyways,Smitty
Old 07-09-2006 | 08:53 PM
Elite Marine's Avatar
Smitty -
Are they pressed bearings or easily replacable? I may do mine on my M1 just for insurance...
Elite Marine is offline
Old 07-09-2006 | 09:03 PM
I'm not sure but you would have to extract your impeller off to get to them and its a very delicate piece,Smitty
baja27
07-31-2006 08:21 PM
BY U BOY
08-09-2005 04:10 PM
baja27
2
04-16-2004 10:10 AM
Freekazz
7
02-11-2004 10:04 AM
Red 230sx
0
10-17-2003 08:32 AM
