Stud Girdle or No Stud Girdle? >
Old 06-29-2006 | 03:38 PM
Default Stud Girdle or No Stud Girdle?
Wondering if I should use a stud girdle or not? Engine builder says I don't need one. I'm having a new 540 put together with Crane Hydraulic Roller cam (~630 lift) with upgraded Dart Iron Eagle heads and Crane Gold roller rockers. RPM will be 5500 at WOT. Do I need to use a stud girdle? If so, what brand do you recommend? I see Crane, Comp and others that are in the $250-300+ range and others (off brand) that are in the $170 range. Are you just paying for the name or are the off brand just as good? Thanks
Corbs is offline
Old 06-29-2006 | 03:47 PM
jdnca1's Avatar
Default Re: Stud Girdle or No Stud Girdle?
Uh......No
Listen to your engine builder
I'm not sure i've ever heard of a stud girdle on a HR cam motor let alone turning only 5500 rpm.
jdnca1 is offline
Old 06-30-2006 | 11:35 AM
Thanks jdnca1. Had a couple of guys tell me I should be using one, so just wanted to set my mind at ease.
Corbs is offline
Old 06-30-2006 | 11:46 AM
articfriends's Avatar
How much spring pressure are you running? I'm running the very max spring pressure a hyd roller can take and turning it up to 5900, I was going to add one because I have had small valve train issues (I tightened comp rocker nuts on the tight side and they were incorrectly heat treated,cracked from stress and backed off) but instead I'm converting over to t/d shaft rokers,Smitty
Attached Thumbnails Stud Girdle or No Stud Girdle?-truck-rearend-003.jpg   Stud Girdle or No Stud Girdle?-truck-rearend-004.jpg
articfriends is offline
Old 06-30-2006 | 11:47 AM
For peace of mind buy the ARP 220,000 psi rocker studs instead of the run of the mill ones,they should flex less,Smitty
Old 06-30-2006 | 03:05 PM
sandman
I have a 615 ci BBC with a HD roller @632 lift. The motor does have crane stud girdles but the engine was originaly built with a solid roller cam. I'm assuming that when the cam was changed, the stud girdles were kept. It would of course make the valve train more stable but I would feel fine without them. I kept them because they were already paid for and there. I would say that you dont need them, but if you wanted to overbuild it, it wouldn't hurt anything either (except your wallet)
sandcraft is offline
Old 06-30-2006 | 06:57 PM
Vinny P's Avatar
I hate the winter!!
Smitty,
I am with you. RMbuilder is designing me a new solid roller for next season. I will also be switching to T&D Shaft rockers. Keep me posted on your results.
Vinny
Vinny P is offline
Back4More
16
03-07-2005 07:49 AM
Strip Poker 388
11
10-31-2004 09:23 AM
Zanie
5
12-13-2003 06:28 PM
Wardey
03-04-2003 10:44 AM
BAD-HABIT
7
06-23-2002 11:02 PM
