Toe In / Toe Out ????? >
Old 06-30-2006 | 08:56 PM
Question Toe In / Toe Out ?????
Need some info regarding toe in / toe out setting for the drives on the boat. Called Fountain today but kept missing the person I needed to talk to about this. Would like to check the setting before launching.
1999 35 Fountain Lightning
Standard Bravos at regular factory X dimension
Props are turning in
Would like to know in or out, and how much. Thanks in advance !
RaggedEdge is offline
Old 07-01-2006 | 03:55 AM
Default Re: Toe In / Toe Out ?????
I've always been told that the bullets should be towed in 1/16th to 1/32nd.
Marginmn is offline
Old 07-01-2006 | 06:55 AM
Hey Robert, I'm thinking in a little myself. Tried the factory yesterday just got busy with chit and kept missing people. Thought someone here might know. Well off to Rochester for Sam's mom's birthday party today, then back here to launch the boat on sunday, try to save some of the weekend. BTW how is yours running ?
Old 07-01-2006 | 08:04 AM
Robert, If you happen to be around LCM the next day or so could you ask them about the toe setting ? Appreciate it !
Old 07-04-2006 | 11:20 PM
I called the Fountain factory once about 4ys ago......I cant remember who I was talking to but he yelled across the shop to a couple of different guys and they went back and forth for awhile and the consensus was "dead ahead.....perfectly straight"......thats what they said......doug
pullmytrigger is offline
Old 07-05-2006 | 08:00 PM
Well finally got thru to Fountain today, and the answer is 1/16 Toe In on the 35. Ran this past weekend at 3/16's toed in and the boat feels good but may be off about 100 RPM, hard to tell that small a difference. Will change it this week and go again.
Old 07-05-2006 | 08:40 PM
How do you measue this?
mustbedreaming is offline
Old 07-05-2006 | 09:12 PM
Best way I have found is to use the center of the prop shaft, the dimple in it, and the center of the leading edge of the gearcase. Toed in would be a smaller, shorter distance at the leading edge than the prop shaft center line, toed out would be the opposite.
Old 06-24-2007 | 06:18 AM
INDY27's Avatar
Did you ever see any more speed with the toe in?
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 06-24-2007 | 06:37 AM
monstaaa's Avatar
toe in
under 90 1 / 16
over 90 1 / 8
monstaaa is offline
