XR stuck in reverse >
XR stuck in reverse
XR stuck in reverse
Old 07-01-2006 | 03:48 PM
LostinBoston's Avatar
Default XR stuck in reverse
My port drive is stuck in reverse. happened yesterday while pulling into my dock after a light run. Gear seem a little tight. is this an easy fix? anyway to salvage my weekend of boating?
thanks
-Rick
LostinBoston is offline
Old 07-01-2006 | 05:01 PM
mats's Avatar
Default Re: XR stuck in reverse
Could be a worn shift cable. If the cable cladding breaks between the transom and the drive you may not be able to get it into neutral or forward gear
mats is offline
Old 07-01-2006 | 05:06 PM
CAVelocity's Avatar
Could be a welded cone clutch, but propbably just the shift cable. You could swap props and dock using the other drive.....
CAVelocity is offline
Old 07-01-2006 | 05:23 PM
mats's Avatar
CAVelocity, what ever the root cause is, swapping the props is a brilliant solution to saving the weekend.
LostinBoston, is the shift control also stuck in reverse or is it just that nothing happens when going into neutral or forward?
mats is offline
Old 07-01-2006 | 05:31 PM
The lever seem to go into neutral position, but the drive stays in reverse. Doesnt lock into foward position. Switching props would be great but the boat is currently in the water (no lift) so that might be really tough to do. Its coming out monday.
Thanks for the advice
-Rick
Old 07-01-2006 | 05:56 PM
mats's Avatar
If the control moves and nothing happens, the shift cable is the prime suspect. If you are lucky it is just an adjustment down on the engine. If it is the cladding you will have to lift the boat to change the cable.
Normally you would be able to shift the props with the boat in the water by putting the drives in trailer position and sit on the swimplatform if you have one. Otherwise sit on the dock or stand in the water.
Good luck
mats is offline
GoCiggie31
12
05-02-2012 01:11 PM
DOCS OUT
07-08-2007 09:23 AM
two-air
8
09-07-2005 10:30 PM
rastus
12
02-11-2004 02:29 PM
LVFASTCAT
5
08-19-2003 08:05 AM
