Motor Compression Problems >
Old 07-06-2006 | 09:58 AM
Default Motor Compression Problems
I am having problems with the motor I have in my boat...its a rebuilt vortec 350 it now has about 12 hours on it now, well I lost rpms and it stalled now it won't start. I do a compression test since i have the tester for that..results not good!
1-140
2-15
3-140
4-140
5-20
7-140
8-40
obviously i have big problems..all the valves seem to go up and down so where should i start next...How can i troubleshoot this to find out excactly why i am losing compression in these cylinders on such a new motor!
-Harry
formula18 is offline
Old 07-06-2006 | 10:36 AM
GOODT's Avatar
Default Re: Motor Compression Problems
short of pulling the heads, you can do a leak down test wkich will tell you exactly where your problem is, as spread out as it is Id have to guess valve issues may be from water in fuel or running to lean
just a guess and my 2 cents
GOODT is offline
Old 07-06-2006 | 12:50 PM
Maybe because its a seven cylinder
1-140
2-15
3-140
4-140
5-20
7-140
8-40
Could not help myself. .. Good luck
1BIGJIM is offline
Old 07-06-2006 | 01:15 PM
Sonic30ss's Avatar
What is the carb and jets, what is the total timing, what fuel are you using, how old are the exhaust manifolds ?
Have to agree with GOODT
Sonic30ss is offline
Old 07-06-2006 | 07:01 PM
i got my numbers mixed up...I just found a blown head gasket already...it was burned out between 5-7 cuasing no compression there...I am still looking into the rest...why would it blow already...it has 12 hours on it
Old 07-06-2006 | 07:14 PM
GOODT's Avatar
torqued incorrectly ??????or overheated
who rebuilt it ??????
GOODT is offline
deanpp
7
02-18-2007 08:55 PM
nocigarette
2
08-21-2006 03:48 PM
DURANGOKID59
07-06-2006 07:19 AM
formula18
4
07-02-2006 05:47 AM
jimjomack
0
07-03-2005 05:06 AM
