TRS drives
Old 07-08-2006 | 06:23 PM
Default TRS drives
Hello,
I need your advice. I would like to buy a 34' boat with TRS drives.
I have heard they are out of production for quite a while. Are there still spare parts available, and are these drives good?
I just wonder while Konrad offers a replacement kit...
heiko
frogger1403 is offline
Old 07-08-2006 | 07:14 PM
lucky strike's Avatar
Default Re: TRS drives
Spare parts are available & they are great drives.
To much hp will hurt them..... Konrad makes a great replacement drive if you have heavy engines.
lucky strike is offline
Old 07-09-2006 | 05:28 AM
are 7.4L = 330HP ok?
Old 07-09-2006 | 06:42 AM
Craney's Avatar
You will be fine. I think TRS are good up to around 600hp. I've had TRS for 3 years and so far no problems,I keep the oil changed and easy on the sticks when taking off with 475 -500 hp.
Craney is offline
Old 07-09-2006 | 07:40 AM
Crazyhorse's Avatar
Mel Riggs has a huge supply of factory TRS parts as well as a highly competent staff in his rebuild shop.
Mel Riggs Marine
920-872-2728
Crazyhorse is offline
Old 07-09-2006 | 11:18 AM
jhiguy377's Avatar
You should be able to run with very little problem if you take it easy; TRS should be ok with 550-600hp; most parts are still available with a bit of searching or from riggs. Good luck -Jeff
jhiguy377 is offline
Old 07-09-2006 | 11:38 AM
el indio's Avatar
Mel Riggs Marine
920-872-2728
Still doing my drives since 1977. TRS with a 330 was a factory package.............Which trans do you run?.........m.m.......
el indio is offline
Old 07-09-2006 | 06:08 PM
StraightJacket's Avatar
We have 750 hp and 680 ft of torque and haven't hurt one yet, Its all on how you treat them some poeple could fu*k up a ball bearing with a rubber mallet if you let em
StraightJacket is offline
Old 07-09-2006 | 07:10 PM
I have 800 hp in front of TRS drives and trans done by Speedmasters.
Only problem I have had was I hit something in FL once and hit something
in Jersey once. ......I dont beat the boat up.
So far been about 6 yrs and no other issues........dont want a bravo boat
but if I sell this one I might have little other choice.
I'm sure those Konrads are good.......but I dont want to put any more
money into this boat and dont really have any problems withTRS.
Mike 35 Fountain is offline
Old 07-19-2006 | 08:22 AM
Biggus's Avatar
I'm now over the 250 hr mark with my Konrads. Zero failures = cheap boating.
Biggus is offline
