pick up coil >
pick up coil
pick up coil
Old 07-09-2006 | 06:02 PM
Default pick up coil
how do you check a pickup coil.... my buddy thought you checked for ac voltage.... did that i read nothing... no fire... have msd coil puts out a spark with turning the key on and turning the key off but not when engine is turning over...
checked the other engine ( that runs) pickup coil when turning over and it didn't read either.... how do you check these things...
Don
chromecat is offline
Old 07-09-2006 | 06:52 PM
GOODT's Avatar
Default Re: pick up coil
easiest way is with a test light put aligator clip on battery + and put probe on - of coil crank mtr if light flashes pick up is ok
GOODT is offline
Old 07-10-2006 | 06:28 AM
thanks.. will check ...
is this likely my trouble... no spark when turning over... i have an msd installed no book for it though.
Don
Old 07-10-2006 | 09:54 AM
Dave_N's Avatar
If you have an MSD box, the above trick using the test light will not work. Bypass the MSD box and see if it runs. Also, check the pickup coil connections at the ignition module. They can get rusty and break off.
Dave
Dave_N is offline
Old 07-11-2006 | 12:10 AM
that looks very nice...
i think mine kinda looks close to that condition.... i ordered a new pair...
Don
Old 07-11-2006 | 12:12 AM
i should still be able to unplug both leads and hook a ohm meter up and see if it bounce the needle though shouldn't I.
Don
Old 07-11-2006 | 08:05 AM
Ted G's Avatar
ohms will not change as it spins, but voltage will in small amounts. However if it is dead it will probably read 0 ohms anyhow.
www.cbpba.com
Ted G is offline
Old 07-12-2006 | 09:08 AM
Airpacker's Avatar
The best way is with a digital storage oscilloscope. A good digital volt meter set on ac volts will also work. Coil disconnected form harness, meter hooked to both leads from coil. The coil will produce a ac signal when excited by the reluctor( the spinning part) if it is functioning BUT even this test is not conclusive as the coil could be shorted internally producing a lower voltage output ( amplitude ) than necessary to trigger the ignition box.
Checking for coil winding resistance is also only a partial test unless you have the actual specification and then it will only tell you if you have a shorted ( 0 ohms ) or an open circuit ( infinite ). Having a second engine right there makes for some easy comparison testing though.
Airpacker is offline
Old 07-12-2006 | 12:45 PM
KNOT-RIGHT's Avatar
I just went through this last weekend.
Unplug the pickup on the distributer.
Unplug the coil wire at distibuter and place it near
something metal.
With Ignition on short the two wires which go to the MSD box.
You should see a huge spark evrytime you short the wires going to the MSD box.
This indicates the MSD Box is working correctly.
The pick up in the MSD Distributer is a coil in itself
should read .04 to.08 ohms.
It is a hall effect setup which is a inductive wheel that
passes by the pickup simulating the above test..
Usualy whem the pickup is bad it reads wide open on a ohm meter.
Hope this helps.
Oh yeah 90 percent of most problems are bad connections.
Good luck
Gerry
KNOT-RIGHT is offline
Pismo10
5
07-04-2007 07:01 AM
MnHowardCat
2
04-23-2006 09:13 PM
Shah Mat
11
12-29-2004 03:50 PM
24outlaw
2
08-13-2002 05:04 PM
