1989 Baja 240 runs hot at high RPM's - help diagnos >
Old 07-11-2006 | 09:20 AM
Default 1989 Baja 240 runs hot at high RPM's - help diagnos
7.4L
230 ~ hours.
160 thermostat.
Temp stays 160 until past around 3,200 then get's progressively hotter as RPM's climb.
At WOT i wasn't paying attention and caught the temp at 210.
As RPM's decrease, the temp goes down accoringly.
I'm told there's a water pump kit consisting of an intake and circulation pump blades that would solve the problem?
I know cars, not much about boats.
Thanks,
M
LS1 MOLESTER is offline
Old 07-11-2006 | 09:39 AM
Default Re: 1989 Baja 240 runs hot at high RPM's - help diagnos
Sea Water Pump. I change mine at the start of each year, instead of getting interupted in the middle of boating season.
Simple change (after you do it once). Do a search, you will find several hits in the past month.
1BIGJIM is offline
Old 07-11-2006 | 10:10 AM
BY U BOY's Avatar
Change The Impeller And Check All Lines For Debris That Could Restrict Flow.
BY U BOY is offline
Old 08-01-2006 | 12:37 PM
You're right.
I thought i could make it through the summer - but it broke down completly the other day and had to get towed.
New sea water kit put in, runs perfect so far so good.
mmillward26
8
08-20-2008 04:33 PM
totalrex
8
08-06-2007 04:08 PM
ApolloMaxim
Northeast US
2
08-06-2007 11:13 AM
grads2112
7
03-17-2004 09:57 PM
Havasu Cig
0
03-17-2004 08:02 PM
