Is there a gasket that goes between.... >
Old 07-12-2006 | 02:01 PM
Default Is there a gasket that goes between....
a Bravo 1 outdrive and the so called bellhousing. Putting a BRavo 1 on for the first time and want to make sure I don't miss anything. I see where the shifter cable latches in , but wanted to make sure there is not a gasket that belongs between them.
I wanted to thank JOE at KI Performance marine and the other guys on the board for helping me answer the questions I need to get my boat back together. I'm going to try to fire the engine this weekend for the first time in the boat after the boat sitting a year!!
Thanks,
shawn
29scarab is offline
Old 07-12-2006 | 02:07 PM
98itrwhite's Avatar
Default Re: Is there a gasket that goes between....
there's a set of o-ring type gaskets that go in there. its called a bravo one gasket kit and sells at the dealer for about 8 bucks. hope this helps good luck
98itrwhite is offline
Old 07-12-2006 | 04:04 PM
Thanks 98 for the input!!
29scarab is offline
Old 07-12-2006 | 06:55 PM
GOODT's Avatar
all that goes there are the o rings I like to put alittle gorrila snot ( 3m super weather strip adhesive ) on them to be sure they dont move while installing the drive
GOODT is offline
Old 07-13-2006 | 11:32 AM
GOODT,
I'm back to working on the boat again tonight. I put the outdrive on the other night and can't remember if I saw them or not, so I'm pulling the outdrive again to make sure everything is in the right spot!!
Thanks guys!!!
29scarab is offline
ak
5
05-12-2008 06:57 AM
daveintexas
14
03-08-2007 08:26 AM
tmdog
10
12-07-2005 03:16 PM
ThirdBird
5
04-25-2005 04:52 PM
Gary Anderson
14
09-22-2004 07:06 PM
