575 sci running rich >
Old 07-18-2006 | 12:37 PM
Default 575 sci running rich
my buddy has a 42 fountain with twin 575 sci.port motor burned 20 more gallons of fuel than starboard motor.swim deck is all black on 1 side and engine loads up.any suggestions on what to look for?
awsomethunder is offline
Old 07-18-2006 | 03:14 PM
Default Re: 575 sci running rich
Float level. Needle and seat leaking. Blown Power Valve.
1BIGJIM is offline
Old 07-18-2006 | 04:32 PM
Not sure what it is but it's not the float since there's no carb.
zahndok is offline
Old 07-18-2006 | 04:39 PM
GOODT's Avatar
could be a stuck injector or a bad/ out of adjustment tps
GOODT is offline
Old 07-18-2006 | 04:41 PM
they are throttle body injection,do you know what the t.p.s volts are supposed to be
Old 07-18-2006 | 04:47 PM
Possibly a bad coolant temp sensor ???
( ecm thinks engine is "cold", dumps more fuel)
JaayTeee is offline
Old 07-18-2006 | 11:35 PM
EWB
Pressure regulator it has an over flow tube that dumps in the throttle body
EWB is offline
Old 07-19-2006 | 08:46 AM
BillR's Avatar
OSO Moderator
TPS voltage should be .59 and base IAC should be 11 - 19.
CHECK the timing using the proper method too.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 07-19-2006 | 01:25 PM
Cattitude's Avatar
I had a map sensor go bad on my 575sci last yr, was way rich at idle/part throttle but by the time I nursed it to 3500 it would drink what it was pouring in. Merc wanted 150ish, it's a GM part, 93 buick riviera 3.8 SC if I remeber right, 1/3 the price. Fixed my issue.
I'm pretty sure the tps should be .5 at idle and 4.7ish at wot, not sure what the iac count should be.
If one injector is stuck it should be obviuous watching it while idling. just remove the spark arrestor and they are in plain sight
Cattitude is offline
Old 07-19-2006 | 02:40 PM
GOODT's Avatar
these are the correct #s
GOODT is offline
lakeman2
7
09-17-2008 06:24 PM
dennis r
1
07-19-2007 08:34 PM
VP
1
07-11-2005 09:56 PM
Quiet Storm
8
02-01-2003 11:02 PM
JOJO
13
09-16-2002 07:13 AM
