What would I have if I took blower off 575sci >
Old 07-18-2006 | 12:40 PM
BL6
Default What would I have if I took blower off 575sci
Just curious, if I bought a boat w/ 575sci's and I wanted to lean to the "turn-key" side vs. blower issues. How dumb would it be to take off blower? (Not saying I would)
What else would that modification require? Reprogram computor module?
Benefits i could think of; dependability, easier on drives (XR's), lower octane gas, could still add better cam.
Disadvantage; speed. torque, hp...
Again, just curious.
BL6 is offline
Old 07-18-2006 | 12:55 PM
Pat McPherson's Avatar
Default Re: What would I have if I took blower off 575sci
I think the 575sci is a pretty mild engine when compared to other supper charged mills...
I don't believe those engines will run vary well without the supercharger as they have a 7.5:1 compression ratio...
The base engines are a 502 so they could be reworked into a 500HP+ NA engines, but IMO a waste...
Patrick
Pat McPherson is offline
Old 07-18-2006 | 02:54 PM
LostCowboy's Avatar
but IMO a waste...
I agree, if the motors are in good shape with good maintenence, you shouldn't have any trouble. The 575's are low boost and don't have detination problems that I'm aware of. That's one big reason you pay extra for the merc power... reliability.
LostCowboy is offline
Old 07-18-2006 | 04:13 PM
If you want to ditch the SC, you'd be better off to try and trade it complete toward a 500 or 525EFI.
Griff is offline
Old 07-18-2006 | 04:27 PM
GOODT's Avatar
junk
the 575 has such low compression that with out the blower it wont get out of its own way
GOODT is offline
Old 07-18-2006 | 04:59 PM
Aside from their appetite, and their slight loss of
power when it gets hot out, the 2 I have (so far)
have been flawless.
Neither of them use any oil ( between change intervals)
Got to agree with everyone elses comments so far.
JaayTeee is online now
Old 07-18-2006 | 05:35 PM
Registered User
I'll trade you for a couple of stock 502's even up.
320es is offline
Old 07-18-2006 | 10:19 PM
BL6
All good answers. Just looking at boats right now, a couple with 500efi & one with the 575sci's. thanks
BL6 is offline
Old 07-19-2006 | 08:50 AM
BillR's Avatar
OSO Moderator
They ARE NOT that thirsty. I have 575's in my TS TG and a buddy has HP500's. Both get almost the same fuel mileage. In fact the 575's get slightly better than his HP500's.
The 575 is a VERY turn key reliable motor. Just like the HP500, you have to do valve springs after 200 - 250 hours. Also you should send the blowers to the blower shop and have them rebuild them. Do that and you should be very reliable and happy. GREAT motor!!!!!!!
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
ciaoderhead
Wanted
0
06-09-2008 09:19 AM
Swamplizard
05-10-2007 02:58 PM
Quiet Storm
1
02-18-2006 05:11 PM
zahndok
15
06-02-2005 11:54 PM
Cattitude
3
10-05-2004 07:15 AM
