Battery Charger in Late 80's Cig >
Old 07-24-2006 | 08:10 PM
gripit's Avatar
Default Battery Charger in Late 80's Cig
In my 88 Bullet there is a battery charger in the engine compartment. It is basicly a big black battery charger. Does anybody know any info about these chargers? Specifically are they trickle chargers or ? Also, my batterys went totally dead because I left the radio on and was wondering how long to leave that charger on so it doesn't cook the batterys.
gripit is offline
Old 07-24-2006 | 08:15 PM
drypipetiger's Avatar
Default Re: Battery Charger in Late 80's Cig
on my rig where the battery switches are there is a volt gauges... to keep track while charging.
I don't find mine to be a trickle charger... It charges very quickly. It's important not to overcharge.
drypipetiger is offline
Old 07-24-2006 | 08:20 PM
gripit's Avatar
Thanks Drypipe,
I also have a volt meter between the battery switches. I just don't know if the charger will turn off when it reaches max. charge.
gripit is offline
Old 07-24-2006 | 08:25 PM
I don't find that mine does.
Doesn't your altinator charge? The radio only uses juice from one battery. When we're anchored if the battery gets to low to start I start from the other battery then switch to the low batt and it charges on the way to the launch.
Old 07-24-2006 | 08:33 PM
gripit's Avatar
True, I do the same thing wile anchoring out. The only thing is that I left the radio on mute all week long so the batterys are totally dead. I had them on the charger for like the last 7 hours.
gripit is offline
Old 07-24-2006 | 08:38 PM
I see... Well that should be plenty. Check your gauge where the switches are. I wouldn't trust that it would shut off automatically.
Old 07-24-2006 | 08:40 PM
JS232's Avatar
It's an alternator not an altinator Shakespeare
JS232 is offline
Old 07-24-2006 | 08:42 PM
He new what I meant... Why aren't you at the gym??
Old 07-24-2006 | 08:49 PM
JS232's Avatar
Why don't you let the electrical experts answer His question and keep your advices for plumbing problems M. Magic Crack plumber?
JS232 is offline
MILD THUNDER
Classic Offshore
3
05-15-2008 02:56 PM
gripit
Cigarette
0
07-24-2006 06:28 PM
formula18
07-24-2006 11:24 AM
superwrench0166
Donzi
1
02-15-2005 07:07 AM
SLEEPER
12-08-2004 01:10 PM
