Could not find the thread.. >
Old 07-30-2006 | 01:22 AM
2112's Avatar
Question Could not find the thread..
About the Oil Pressure switch that will cut the ignition or fuel if the oil pressure drops too low.
It had a name I can't remember, Thought someone suggested Mcmaster Carr as a source.
Anyone remember thread?
2112 is offline
Old 07-30-2006 | 07:00 AM
GOODT's Avatar
Default Re: Could not find the thread..
you can buy it throuh merc also
Attached Thumbnails Could not find the thread..-l125.jpg   Could not find the thread..-l124.jpg
GOODT is offline
Old 07-30-2006 | 08:56 AM
nordic95's Avatar
I bought mine at summit racing for 16.00. It works great,I lost a pick up tube off my pump two weeks ago and it saved my engine.Best 16.00 dollars I've ever spent.
www.summitracing.com
Thanks Nordic95
nordic95 is offline
Old 07-30-2006 | 12:42 PM
2112's Avatar
Thanks Nordic95
Was it a holley piece? Remember what they called it?
2112 is offline
Old 07-30-2006 | 02:34 PM
nordic95's Avatar
It was a Holly piece.I think it was in the carb section of the link.It has 1/8 pipe thread and three wire connections.You can use it as a normally open or normally closed circuit interrupt.I taped it into my hot coil wire to trigger the relay I wired into my electric fuel pumps.When alarm sound for low oil pressure pump shuts off and gives me a few seconds to come off plane while carb bowl emptys,then shuts off.I dont like the idea of shutting ignition off automatically because I may not be in a safe situation to just shut down.
Nordic95
nordic95 is offline
Old 07-31-2006 | 12:54 AM
2112's Avatar
I too had it rigged to fuel pumps in my last boat, but things happen so fast at rpm that I was thinking ignition may shut it down faster preventing more damage if something goes wrong.
2112 is offline
Old 07-31-2006 | 01:20 AM
2112's Avatar
Do you remember what they are called? I have tried several key words and scrolled though 60 pages of holley stuff, Can't find them.
2112 is offline
Old 07-31-2006 | 07:03 AM
nordic95's Avatar
part number is HLY-12-810.Sorry its 21.98 not 16.00.
Nordic95
nordic95 is offline
Old 07-31-2006 | 10:39 AM
2112's Avatar
Thanks, Ordered them. Man, you would think keywords Holley, fuel/oil pressure relay switch would have brough that up!
Any further thoughts out there regarding using it as a ignition cut off vs. a fuel cut off?
2112 is offline
Old 07-31-2006 | 10:52 AM
Hobbs switch.
Sierra makes a "marine" version. Not sure there's a difference, but that's who I bought mine through.
BTW, It's not designed to save your engine. It's designed to prevent fuel from an electric pump from flooding your engine compartment with gas if the engine stops. ie, a stuck float.
Gary
rdoactive is offline
