trailer tire pressure?
Old 07-30-2006 | 08:28 PM
tblrklakemo's Avatar
SeaRay Sundancer
Default trailer tire pressure?
do you guys fill up to the tire manufactures suggested psi on your trailer or what? What should i run? tandem axle, 3900lbs boat, dont have the wheel tire specs sorry(i think they are 15's and maybe a 235/75?)
tblrklakemo is offline
Old 07-30-2006 | 09:41 PM
mopower's Avatar
Toxic FORMULA
Default Re: trailer tire pressure?
That weight may be 14 inch wheels. Check the sidewalls for tire specs. Should also have tire pressure specs. And yes , I inflate to max recommended pressure
mopower is offline
Old 07-31-2006 | 03:19 AM
BLAZE's Avatar
ENABLER
Max psi listed on sidewall is what I always use!
BLAZE is offline
Old 07-31-2006 | 09:37 AM
SeaRay Sundancer
great....i don't happen to be close to my trailer and i haven't looked at the tires/wheels since i bought it. The only reason i ask is that car manufactures and tire manufactures have different psi suggestions, so i thought the trailer manufacturer might too.
Old 07-31-2006 | 02:18 PM
Wobble's Avatar
SORE MEMBER
Probably 35 psi but may be more if they are rated as trailer tires. I always go with the max cold psi on the side of the tire because when I am making a tight turn with my triple axle I don't want to pop a bead.
Tires run coolest at higher pressures (less flex), however, if they are wearing out in the middle of the tread then you might want to experiment with a lower pressure ( in 5lb increments)
Wobble is offline
Old 07-31-2006 | 02:46 PM
Downtown42's Avatar
As above, go with max cold sidewall psi. Mine are 80 max. on truck and trailer.
Downtown42 is offline
Old 07-31-2006 | 05:15 PM
Strip Poker 388's Avatar
Rob
same here 80 truck and trailer 235-85-16s'
On my old Scarab I ran 5 pounds higher because I was over the rated weight by 30 pounds each tire. trying to keep the side wall from flexing as much which creates heat
Strip Poker 388 is offline
Old 08-03-2006 | 05:13 AM
mama tryed's Avatar
Check the tire cold, then if the sidewall says 60 lbs, put it at 60lbs. anything less causes excessive heat build up, which is the major cause of tire failure, trailer or truck.
Mitch
mama tryed is offline
Old 08-03-2006 | 06:53 AM
augie58's Avatar
give some thought to the age of those dounuts. if they are more than 7 or 8 years old give some serious thought to replacing them. nothing ruins a good day boating more than sitting on the side of the road with a blown tire.
augie58 is offline
jmackin
11
04-15-2008 02:00 PM
masi242
8
04-01-2008 05:42 AM
Donzi Corleone
13
02-02-2008 12:33 PM
patrick22309
08-06-2003 07:45 PM
