2000 Baja 24 ft 454 EFI
This boat has a closed bow and 454 EFI (325hp) bravo1 what prop should my friend run??? I assume it is 1.5 ratio drive he had a three blade ballistic on it. He doesn't know the pitch on it.
A 23 pitch prop would be a good start. Something like a Mirage 23 would be a good starting point and go from there.
You will want that motor running about 4400-4600 at max speed.
I agree the Mirage Plus is the prop to try. 23 "may" be too high. Try any one you can find from 19, 21 or 23 pitch.
[email protected]
[email protected]
