oil lines and oil coolers >
Old 08-02-2006 | 08:02 AM
dean51267's Avatar
Default oil lines and oil coolers
Who has good after market oil lines and oil coolers? Looking to replace stock stuff. Thanks.
dean51267 is offline
Old 08-02-2006 | 08:39 AM
Default Re: oil lines and oil coolers
Is it a Mark 4, or Gen 5 or 6 motor?
rdoactive is offline
Old 08-02-2006 | 08:41 AM
dean51267's Avatar
I am removing gen 5, and going back with gen 6.
Old 08-02-2006 | 08:48 AM
Since you dont need the filter bypass in the Mark 4 "coffee can" oil filter adapter, you can get all aftermarket stuff.
On my last Gen 5 motors, I bought aftermarket adapters and remote filters. Then I made my own S/S AN lines and used NPT to AN adapters on the fittings.
Any aftermarket stainless hose is going to be better than the merc ones, and you dont have to deal with the oddball inverted flare hoses they use.
Gary
Old 08-02-2006 | 11:53 AM
GOODT's Avatar
DEAN
Checkwith your local parker hose dealer they can make you anything you want at a fraction of what youd pay elese ware
GOODT is offline
Old 08-02-2006 | 02:33 PM
RLW
Keep in mind the temperature rating of the hose.
RLW is offline
Old 08-02-2006 | 03:05 PM
For hose, I would agree with GOODT. If you dont care about the pretty stainless braided hose and aluminum ends, you can use rubber coated hose and brass ends for a third the price.
They even have Push-Loc that is rated for those temps and pressures.
BTW, the bigger Merc oil coolers (ie 500hp) are fine for most applications. But once again, you can get the pretty chrome plated aftermarket brass ones for a few bucks more.
Gary
Old 08-02-2006 | 06:07 PM
i have a 365 mag motor that has been reworked. i threw out the little oil cooler that comes stock and bought a combo p/s-engine oil cooler from revolution marine. it's 3" in dia. and about 20inches long. my motor has about 15hrs.on it,and i am pleased with the cooler. it's also very reasonably priced. i used a cloth braided rubber hose from good year that was rated at 300psi and 300 deg. temp. brass push-lock fittings were easy to deal with, and were rated for a ton of pressure.good luck.
rlv1017 is offline
Old 08-02-2006 | 11:45 PM
dean - try a search for AN and or oil lines. smitty or KAMMA, or someone, did a great thread on the subject. Damn...I can't remember who done it But it is a must read if you're going to get nto changing oil lines. VERY informative.
Kidnova is offline
Old 08-02-2006 | 11:49 PM
btw..stock merc oil lines and fittings are just BARELY 3/8 in. ID, at least on the black motors. Not enough ID for say 500 hp. Oil temp gauge will tell you that.
Kidnova is offline
