New one on me, 01 F250
Old 08-03-2006 | 10:25 AM
Playn's Avatar
Default New one on me, 01 F250
Went to change the oil today and the oil change place wouldn't do it because the oil pan was rusted. They said it's the 4th one they've seen lately. I took it to Ford for a quote.............................$1700.00 to replace the oil pan. After looking, it looks like it is a pain in the azz to do. Somehow I'd think an oil pan should last a tad bit longer than 5 years
just venting..
Playn is offline
Old 08-03-2006 | 10:32 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Re: New one on me, 01 F250
I think it has to do with where you live and what they do to the roads. My Ford F-350 is a 2000 with not a spec of rust on it, and it came from Connecticut. I think they use a lot more salt in the Midwest than they do out East, as they use more sand other treatments.
How bad is your pan? Is it rusted to the point of losing its integrity? Can you sand it down and paint and undercoat it; perhaps beef any areas up with JBWeld? I would not have Ford do the change anyhow. Find a good shop with plenty of great references and have it done there.
Sydwayz is offline
Old 08-03-2006 | 10:54 AM
czy40p's Avatar
I have heard that some roads are being treated with a spray on de-icer that is incredible corrosive. (corrodes things much faster than salt would). It is mainly used on bridges overpasses. That sucks about a needing a new pan. I would spray the pan down with some penetrating oil and try a different shop. Did you ask FORD to change the oil?
czy40p is offline
Old 08-03-2006 | 12:13 PM
mrv8outboard's Avatar
coolrunning racing
is it a diesel? they rust out and it is a known problem. i will check to see if i can find the tsb in them.
mrv8outboard is offline
Old 08-03-2006 | 01:34 PM
Playn's Avatar
Yes it is a diesel. I have several others a (97, 04, and 05) with no problems though.
Playn is offline
Old 08-03-2006 | 05:48 PM
CMG's Avatar
CMG
Suck the oil out with a marine pump up thru the oil dipstick and trade in at a Ford Dealer. Be glad its not a gasser, my 03 F250 5.4 w/50K exhaust manifold bolts are already rusting thru. I had one stud rot off and replaced the entire starboard side. Ford oil pans, spark plug and exhaust manifolds have been rusting to chit for almost 10 years - you'd think they'd do something about it?
Chris G.
CMG is offline
Old 08-07-2006 | 12:51 PM
Playn's Avatar
Well, after my conversation with them and asking why I should continue to buy Ford trucks from them (currently have 4) I got this email from the Ford dealer;
"I spoke to our service manager, xxxx xxxxxxxx, about your oil pan problem. He said "if the vehicle is 5 years old or less, then Ford would pick up all of the repair cost. It would also need to have less than 100 K miles." In your situation, all he could do is offer a discount on the repair."
Better than nothing I suppose..
Playn is offline
Old 08-07-2006 | 07:16 PM
CMG's Avatar
CMG
F em, Buy a Nissan
Chris G.
CMG is offline
88formula223
32
03-26-2007 08:11 AM
nitroracer1
20
04-23-2006 09:15 PM
mrb30
5
05-25-2005 09:24 PM
BGIII
01-24-2005 02:06 PM
rv
03-04-2002 08:59 AM
