Crack in trs lower >
Crack in trs lower
Crack in trs lower
Old 08-03-2006 | 08:35 PM
Default Crack in trs lower
the crack is on the lower side of the drive. Perpendicular to the spanner nut. What causes this? I am guessing that the lower is pretty much N/G. What could of happened if i never saw it?
thanks
djtalon is offline
Old 08-03-2006 | 10:13 PM
Audiofn's Avatar
Charter Member #232
Default Re: Crack in trs lower
More then likely corrosion, or the drive was left trimmed up and water froze in it. I have had luck welding mine up when it did that from corrosion. If you keep using it eventually the drive will blow and a lot of expensive parts will sink to the bottom along with your prop more then likely. I eventually purchased a new case.
Jon
Put your best foot forward!
Audiofn is offline
Old 08-03-2006 | 10:36 PM
GOODT's Avatar
most likely from corrosion around the retaining ring and prop shaft carrier
GOODT is offline
Old 08-03-2006 | 10:44 PM
A good welder can probably fix that. With the price of these things nowadays its worth looking into.
scottie150 is offline
Old 08-29-2006 | 05:12 AM
Mine was heavily damaged by corrosion.
I fixed it by welding a ring over the complete spanner nut area.
No problems with shaft alignments, if welder works carefully.
Ring thickness was 0,2 inch and should be ground down a little bit (after welding) in order to reduce the increased drag.
Joee
Attached Thumbnails Crack in trs lower-trs_gear_housing_crack.jpg   Crack in trs lower-trs_gearhousing_welded_600x450.jpg
joee is offline
Old 08-29-2006 | 09:53 AM
Lofty's Avatar
Here is how I would fix that problem.
Attached Thumbnails Crack in trs lower-tn_konrads1.jpg   Crack in trs lower-tn_konrads2.jpg
Lofty is offline
martins custom marin
Wanted
1
09-10-2008 08:07 AM
inxs01
Wanted
0
05-04-2008 07:43 AM
Andy
Wanted
6
01-11-2008 02:00 PM
Boomer35
6
11-01-2005 09:10 PM
Boomer35
10-07-2005 07:06 PM
