Big Block Circulating Water Pump >
Old 08-04-2006 | 08:47 PM
Default Big Block Circulating Water Pump
Today my circulating water pump started to drip from a hole under it. (Picture). The engine has not closed cooling.
Is there something I can do, or do I need to replace it?
Can I use a automotive pump or does it have to be a marine one?
If any, what are the difference between them?
Hydrolift is offline
Old 08-04-2006 | 08:52 PM
Vinny P's Avatar
I hate the winter!!
Default Re: Big Block Circulating Water Pump
You need to replace that pump. The internal seal is bad and will only get worse. I would use a marine pump. The difference is the marine pump had a stainless impeller and backing plate.
Vinny P is offline
Old 08-04-2006 | 09:08 PM
Ordering one right now. Thanks for the info.
Old 08-04-2006 | 11:13 PM
GOODT's Avatar
True, what he said
GOODT is offline
Old 08-05-2006 | 11:19 AM
My question is, why not just put a cross over on instead of using another circulating pump?
chase n us is offline
Old 08-05-2006 | 12:04 PM
Happened to mine as well 1968 corvette 427 pump. changed one on my small block years ago with a corvette small block pump also a 68. Both have run fine and fit perfect with no problems
k24u is offline
Poorsche
14
08-30-2004 12:25 PM
challenger454
9
05-16-2004 06:25 PM
Fuhgedaboudit
28
04-11-2004 02:37 PM
horizontalboggi
5
05-12-2003 05:14 PM
Thirsty Turtle
1
04-21-2002 11:33 AM
