Big block starter options >
Old 08-11-2006 | 09:39 AM
Default Big block starter options
Need to replace the starter on the boat. Having problems finding a starter for the boat locally.
Is there a starter at the local autoparts that will fit a 502mpi engine until I can get a good marine starter. If so,,,does someone have the part number for it? If not ,what are my options?
Thanks ,
Shawn
29scarab is offline
Old 08-11-2006 | 09:46 AM
Default Re: Big block starter options
Shawn,
Look in the yellow pages for a starter altenator rebuilder. 99% of the time the starter can be rebuilt in a day or less.
I would not recommend putting a car starter on it.
cstraub is offline
Old 08-11-2006 | 09:53 AM
White Knuckles's Avatar
I just took my 29 Scarab in to the shop because of hard starting. I called this morning, and they have already ordered me a new starter. They did not even call to let me know. I think that most starters run around $200 for the 502 engines.
White Knuckles is offline
Old 08-11-2006 | 10:05 AM
Years ago I dealt a company around Lauderdale. . .AES....Auto Electric Supply. They sell marine starters resonable.
cstraub is offline
Old 08-11-2006 | 10:12 AM
I was a little pissed because they did not call me first. I thought that it might be the silenoid as I could hear a clicking when batteries were connected before as it energized, but now there is no sound at all when connecting the batteries. Also, there was a strong electrical smell when trying to start the motor.
Old 08-11-2006 | 10:14 AM
If they are selling you a new one then there will be no core charge. Ask for the old one and take it to a rebuilder. You should be able to get a good as new starter for around $85 repair bill. Then you will have a spare.
cstraub is offline
Old 08-11-2006 | 10:18 AM
Good point. Thanks
Sorry 29scarab, I did not mean to hijack your thread.
Here is a link for Mercruiser parts.
http://www.mercruiserparts.com/mercruiser_parts.asp
Old 08-11-2006 | 11:39 AM
Appreciate the input !! I'm going to go online and see what I can find.
29scarab is offline
Old 08-11-2006 | 11:45 AM
Wobble's Avatar
SORE MEMBER
Thanks ,
Shawn
Rebuild is cheapest option, if you are going aftermarket, consider a reduction gear mini starter. These can be clocked to provide more clearance for aftermarket oi pans, $160-$200 from most speed shops or Summit etc.
Wobble is offline
Old 08-11-2006 | 11:50 AM
SB
www.dbelectrical.com sells the small GM style hi torque marine starter for around $110. I've used a few and have outlasted my $210 Napa marine one's.
Just my experience which is just a handful of replacements.
BTW: always get new bolts with a starter replacement. A broken starter bolt in a boat will likely ruin your day, week, or even two.
SB is offline
