Tach fluctuates over 4500 rpm >
Old 08-15-2006 | 05:59 AM
vandeano's Avatar
Default Tach fluctuates over 4500 rpm
My Tach starts to fluctuate when it hits 4500 rpm. Below that it is steady, but once it hits 4500 rpm it fluctuates to 5000 rpm. This is a new Tach, my old one didn't do this. This is a AutoMeter Marine Tach. I double checked all the wiring. Even ran a separate ground with no avail.
vandeano is offline
Old 08-16-2006 | 06:46 PM
vandeano's Avatar
Default Re: Tach fluctuates over 4500 rpm
I take it Im on my own on this
vandeano is offline
Old 08-16-2006 | 07:16 PM
Ted G's Avatar
I just had one doing it over 4000 and it turned out to be the distributor, play in the shaft was causing the pole piece to give varying signal at high rpm. New dist and it's rock solid to 5000. 96 502 EFI with Gaffrig tach.
www.cbpba.com
Ted G is offline
Old 08-17-2006 | 02:01 PM
vandeano's Avatar
Thanks, I'll check it out.
vandeano is offline
Expensive Date
06-01-2010 04:05 PM
mats
1
05-15-2006 02:06 PM
FormulaM2Formula
03-14-2006 10:37 AM
Dregsz
1
02-02-2006 06:59 AM
Krumbsnatcher
26
07-17-2003 11:43 AM
