Will Silent choice for Bravo bolt up to TRS drive?? >
Old 02-05-2002 | 06:38 PM
panteraracin
Question Will Silent choice for Bravo bolt up to TRS drive??
I have a guy that wants to buy my silent choice but he has twin TRS drives and i had the kit installed on Bravos. Are the two compatible or is there some kind of adapter. Thanks in advance
Old 02-05-2002 | 07:13 PM
DJD
Post
I had silent choice for Bravos set up on TRS's on my old boat.
The trick to making it work is to get stock TRS inner exhaust elboes that bolt to the inner gimbal plate with three bolts per side(Merc dealer).
Then, you get rubber connecting boots that go from 4" down to 3" (Boat U.S.).
I hope this helps, let me know if you need more info.
Dave
DJD is offline
Old 02-05-2002 | 08:15 PM
panteraracin
Post
Can you use the bravo wishbone pipe or y-pipe that comes w/ the system or do u have to make something up w/tubing and the hose reducers you mentioned? Thanks
Old 02-05-2002 | 09:26 PM
David's Avatar
Post
The stock inner TRS pipes take the place of the Bravo "Y" pipe
David is offline
Old 02-05-2002 | 10:07 PM
Wally's Avatar
Were doomed!
Post
Originally posted by panteraracin:
<STRONG>Can you use the bravo wishbone pipe or y-pipe that comes w/ the system or do u have to make something up w/tubing and the hose reducers you mentioned? Thanks</STRONG>
The bravo Y-pipe will not work with the TRS setup. The TRS uses two individual pipes not a "Y" like the bravos do...
I'm sure you can still get the TRS pipes from Merc if need be...or maybe someone here may have a set for sale
-Wally
Wally is offline
bermudaboy
Scarab
0
01-23-2005 11:13 AM
boot
07-06-2004 07:37 PM
lucky strike
3
06-19-2004 06:46 PM
edb07
3
07-22-2002 01:03 PM
panteraracin
3
02-07-2002 10:36 PM
