msd or thunderbolt 4
I've used the Tbolt on two performance engines so far with no problems. 1st was a 406 small block with 10:1 with solid lifter cam. 2nd was current 540 at about 550 hp. I would spend $$ on other items first.
I would be interested to hear who is using Tbolt on big HP engines, and what HP?
Originally Posted by Griff
TB IV dist with a Crane Box.
I have 625 hp NA 540s (9.3 c/r)with T-Bolts. Work fine and top of the chart for reliablity
MSD
T-Bolt distributor and Crane boxes are good too but I don't feel the advance curve is that critical on a boat. Biggest importance is you overall timing and let the idle timing fall where it may.
MSD
Totally impessed with TB IV on hp marine engines.
Totally impressed with Crane HI-6M on marine engines.
Not to keen with the MSD system on marine engines.
The TBIV distributor does not have the corrosion problems that plague the MSD's.
Marine engine's - for the most part - don't turn mega rpm and/or create super high cylinder psi that over burdens a mild powered ignition system. A way too lean or way too rich condition will run better with a CD ignition, but, this is marine and we have things tuned correctly right ? If we have an application that idles a ton and tends to foul plugs and we have tried everything to tune this out, then a CD box will help big time. Just skip buying a corrosion prone distributor, keep the stock one, and add a much more reliable (then MSD) cd box from Crane.
Registered User
Originally Posted by fastedy
I was told to use the T-Bolt system and that the NASCAR Guys run multiple systems for a reason.
Registered User
Originally Posted by osen007
I have a 502 650 hp. should I go msd or thunderbold 4? msd has a big box when the thunderbolt looks eaiser what are your thoughts
