Messy Oil Filter Removal >
Old 08-21-2006 | 11:48 AM
BeakBoater35's Avatar
Default Messy Oil Filter Removal
I have 1997 Mercury HP525SC motors. The oil filters are located on the back of the motors.
Removing the filters I spill oil into the bilge. I have tried rags and platic bags to catch the spill with minimal success.
Is there a better way?
Joel
BeakBoater35 is offline
Old 08-21-2006 | 12:39 PM
Downtown42's Avatar
Default Re: Messy Oil Filter Removal
Try unscrewing oil filter just enough to break the seal. Wait 20 min and remove... see if that helps.
Downtown42 is offline
Old 08-21-2006 | 01:31 PM
TeamTaboo's Avatar
TeamTaboo
And when you are done pour some Joy soap in the bilge to cut the oil
TeamTaboo is offline
Old 08-21-2006 | 04:49 PM
Presumably this would break a vacumm and allow the oil to drain back into the motor? Would oil also leak out into the bilge?
Old 08-21-2006 | 04:53 PM
Downtown42's Avatar
1. yes
2. only if it dribbles
Old 08-22-2006 | 06:41 PM
carney's Avatar
I have the same problem. I have heavy real heavy plastic bags and have to take a few extra min to get the bag in place and this works ok for me. If some gets away ,I use the purple cleaner from walmart and hose it fast . Good luck.
carney is offline
Old 08-23-2006 | 06:57 AM
Thank you for your response.
Kinda amazing that for the money these toys cost a bit more thought wasn't put into design!
Old 08-23-2006 | 11:23 AM
Question Re: Messy Oil Filter Removal
Anybody thought of or installed remote oil filter kits. I have had them in a larger sportfish boat. They are then right where you want them.
bgriff is offline
Old 08-23-2006 | 11:52 AM
itilldo's Avatar
do you have any pics of the set up your are talking about
itilldo is offline
Old 08-23-2006 | 01:31 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
If the filters are inverted, meaning pointing down...
Take a screwdriver that has a square shank about 3/8 in diameter, and pop a hole in the very top center of the filter with a hammer. Let the screwdriver insert a couple inches, but not far enough to extend out the bottom of the filter. Let the filter drain into the pain for about 20-30 minutes before you remove it. You will not spill a drop; guaranteed... as the filter will be empty.
I have a specific screwdriver that I cut and sharpened for this task. It works like a charm.
Sydwayz is offline
