Which prop should I use?? >
Old 08-21-2006 | 05:51 PM
Default Which prop should I use??
I have a "92" Baja 240 (454), I damaged my prop and need to replace it. I had a 23p on it.. A friend of mine has two spare props but we are not sure what the pitch is . One is a three blade , on the hub its marked Michigan Wheel 14 1/4 x 26 .
The other is a four blade , both fit my shaft..
Thanks ,
Wayne
ippon is offline
Old 08-21-2006 | 06:04 PM
Payton's Avatar
Charter Member #927
Default Re: Which prop should I use??
The 26 is the pitch. Michigan Wheel props are a little less performance oriented. Not sure what that will mean to your boat. Maybe simply lower top RPMs, maybe not care the bow quite as well. Won't hurt anything to try, unless you spin the rubber bushing on the prop hub. I've never seen a Micgigan Wheel with a solid hub.
Payton is offline
Old 08-21-2006 | 06:51 PM
Best overall prop would be a 22" Bravo 1, best top end is a 23" mirage plus.
Griff is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
