who wants to lend me a 496ho scan tool >
Old 08-22-2006 | 06:28 AM
hp500efi's Avatar
Member #9
Default who wants to lend me a 496ho scan tool
Anyone out there that wants to borrow me a Merc scan tool so that I can scan my motor?
I have one motor that is giving me the 2 beep alarm and I would like to find out for myself what it is and fix it.
I am willing to pay for all shipping costs back and forth.
Jeff
Member of the Liquid Jungle
hp500efi is offline
Old 08-22-2006 | 04:06 PM
hp500efi's Avatar
Member #9
Default Re: who wants to lend me a 496ho scan tool
hp500efi is offline
Old 08-23-2006 | 11:19 AM
Jeff
I had the same intermittant problem during some really hot days last month..No luck on any forums on a fix for it except to get a scan tool...All gauges were fine and it ran fine, just a 2beep alarm every min or 2..Then it mite not alarm the next time u go out.I did however change the water seperator before we went out last weekend and the alarm never went off. when i got back I changed the lower unit oil.. too early to tell if it did any good.let me know if u find a fix..
bco 496
bcolmsted is offline
Old 08-28-2006 | 09:22 AM
Heres a new twist to this alarm puzzle...We were out 5 hrs Friday with NO alarms, then Saturday (Temp. much hotter that day) it started the 2 beep alarms again..Noticed I cud shut off engine, but leave ignition on and the alarms kept coming..After a half hour or so, NO alarms rest of the day..
BCO 496
Old 08-28-2006 | 12:57 PM
Downtown42's Avatar
I'm assuming all your fluids and resevoirs are full.
Downtown42 is offline
Old 08-28-2006 | 01:06 PM
Im getting the same alarm on a 350 mag motor,two short beeps every 2 minutes.All fluids are good and gauges are right where they should be.
tommymonza is offline
Old 08-28-2006 | 04:12 PM
This is getting scary! See my post under the 350 Mag thread about the 2 beep alarm. Just bought a boat with a pair of '02 6.2MX motors and during the sea trial (about .7 hours run time on motors) the alarms never went off. Got it home and within 5 minutes after loading the family in the boat, started getting the 2 beep alarm on starboard engine ... disconnected the drive bottle sensor, so I know it is not that (and the drive bottle was at the "full" mark anyways. Manual says that is the only thing that will give a 2 beep signal. Talking with Mercury Tech Assistance was of no value whatsoever ...
bob_t is offline
Old 08-28-2006 | 05:42 PM
had a few water temp sensors go bad drove me nutz and theyre only plastic so be careful taking them out
Baddogg is offline
Old 08-28-2006 | 06:12 PM
This boat is a year old with 125 hours and dry stacked.Motor compartment is dry as a bone.
Old 08-28-2006 | 06:23 PM
might be a H20 pressure sensor mounted in the cooler behind bellhousing.
had a few go bad, 2 beep alarm but usually goes into guardian mode and rpms wont go over 4000 rpm. without a scanner, disconnect elect connector and ohm out, if its open replace it
with a scanner h20 pressure will read 0 hope this helps
by the way - sometimes doesnt store a hard code
lookinforboats is offline
