Keeping an EFI fuel pump primed >
Old 08-26-2006 | 08:07 PM
Grog's Avatar
Default Keeping an EFI fuel pump primed
Looking for some input from someone that has been through this.
I have a SX performance fuel pump feeding the fuel rail of my 502 through an Aeromotive inline filter (10 micron) on the high pressure side. On the low pressure side is a 1/2" input/output water fuel seperator (100 micron) through 1/2" line from the tank.
When the boat sits for a few days, I lose my prime to the fuel pump and the boat is hard to start. I know the pump is higher than the bottom of the fuel tank but I can't mount it any lower than it already is.
Is there a low pressure pump that would work in-line between the tank and the input side of the SX pump? Or, is the answer that I have to keep my tank full?
Grog is offline
Old 08-26-2006 | 10:00 PM
zt260's Avatar
Default Re: Keeping an EFI fuel pump primed
Put a fuel check valve inline. It worked for me. Summit sells them.
zt260 is offline
Old 08-27-2006 | 01:49 AM
Grog's Avatar
ZT260 - I hear ya' but the HP fuel pump manufacturers recommend not putting any restrictions between the pump inlet and then tank. It is a supercharged application. What you say to do makes the most sense but....... between the fuel pump mfg and the SC mfg.....I am paranoid about installing anything between the tank and the pump. I'm sure they are covering their a$$.
Grog is offline
Old 08-27-2006 | 06:57 AM
zt260's Avatar
You need to check is your fuel pressure before and after you install the check valve. If it's the same your good. I'm running two electric aeromotive fuel pumps in parallel to feed my EFI blower motor. I have a check valve on both pumps. If one quits I’m still ok at anything less than WOT. It works perfect.
Here’s the part number from Aeromotive. AEI-15107
Summitracing has them.
zt260 is offline
Old 08-27-2006 | 12:12 PM
Grog's Avatar
Thanks zt! I'll give it a shot.
Grog is offline
Old 08-27-2006 | 02:32 PM
zt260's Avatar
Let us know how it works out.
zt260 is offline
Old 08-27-2006 | 03:17 PM
SB
An Aeromotive engineer told me to run the pump lower than the pump inlet fuel line and outlet line - kind of like a sink / toilet trap. This keeps some fuel at the pump.
SB is offline
Old 08-27-2006 | 04:28 PM
zt260's Avatar
Yes that should work, but I could not do that. Good luck.
zt260 is offline
Jim Diesel
2
09-03-2008 07:40 PM
Dock Holiday
6
10-10-2007 06:52 PM
Fountain38
2
05-16-2007 05:42 PM
Quent
2
10-29-2006 09:57 AM
Quest for Speed
4
02-12-2004 07:21 PM
