Gimble Rings & bell and.......
We have NEW take off Gimble Rings with the Bell & trim limit/sender
on the shelf and ready to go.
Merc part #822374A4
Retail from Merc for $849.90
your from TEAGUE CUSTOM MARINE for $424.95
thats 50% OFF
Merc part #822374A4
thats 50% OFF
everything should fit right up no problem.and these are new
with no hours. if you are replacing this part i am just going
to assume that you have a lot of play in you steering, if this is
the case then you may not need the pin. if you havent taken
it apart yet you may want to do so first before you order the
pin to make sure that it is bad or good (probably good). the
pin costs $254.93
pin costs $254.93
you do not have to remove the transom assy from the boat to do the repair and i still have some available so give me a call and lets get your name on one.
