Merc 150 Blue Water Series >
Old 08-29-2006 | 12:54 PM
BY U BOY's Avatar
Question Merc 150 Blue Water Series
My Ob Will Start And Run But After About 20-30 Min It Dies And Will Start Right Back Up And Does The Same Thing. I Have Changed All The Fuel Filters And Seperators And Also Pulled And Cleaned The Carb But Is Still Doing The Same. 1999 Merc 150 With About 300 Hours. What Should I Look For? Any Help Is Great Thanks Patrick
BY U BOY is offline
Old 08-29-2006 | 01:10 PM
BY U BOY's Avatar
Default Re: Merc 150 Blue Water Series
Could This Be A Ethanol Related Problem?
BY U BOY is offline
Old 08-29-2006 | 01:20 PM
BAJA342's Avatar
Charter Member #1251
Did you check or replace the fuel line itself? Maybe try is with temp. fuel to see what happens then.
BAJA342 is offline
Old 08-29-2006 | 01:26 PM
I had a 150 EFI with the same problem. Not sure if the carb would be the same. Merc had some bad voltage regulators that would charge to high. When the voltage went above 15 volts, the ignition would shut off the engine. Mine would die, I could hit the key before the boat would come off plane and it would start right up.
Island Time is offline
Old 08-29-2006 | 01:27 PM
BY U BOY's Avatar
AFTER CHANGING EVERYTHING I RAN IT WITH A PORTABLE 10 GALLON TANK AND DOES THE SAME THING.
BY U BOY is offline
Old 08-29-2006 | 02:21 PM
Wobble's Avatar
SORE MEMBER
I guess that rules out a fuel tank vent problem, which was my thought.
Wobble is offline
Old 08-29-2006 | 02:29 PM
BY U BOY's Avatar
I 'M STUMPED. I QUESS I WILL HAVE TO HAVE A BUDDY IN LA BRING TO A SHOP FOR ME SINCE I WILL NOT BE BACK HOME UNTILL THE END OF SEPT.
BY U BOY is offline
bermy100plus
05-28-2013 08:34 PM
gettin wet
10-09-2008 10:30 AM
timber
1
12-09-2006 11:32 AM
