Scan results....need help >
Old 08-30-2006 | 06:56 PM
hp500efi's Avatar
Member #9
Default Scan results....need help
This is from my one motor that is giving me the 2-beep soft alarm. Can anyone look it over and give me an idea what to look for? I did recently change my broken shift cable ... and it started 2 runs after that cable was changed..
DIACOM ® Diagnostic Status Report
08/30/2006 18:41:25
1. VEHICLE CONFIGURATION
Engine Make: N/A
Engine Serial No: N/A
Model Year: N/A
System Type: MerCruiser PCM555
2. PERFORMANCE DATA
Parameter Description Value Unit
Engine Speed 666 RPM
Available Power 90 %
Coolant Temperature 158.00 °F
Fuel Flow Rate 1.53 GPH
Port Exhst Cool Temp 98.60 °F
Sea Pump Pressure 43.46 PSI
Starb Exhst Cool Temp 98.60 °F
IAC Duty Cycle 19.16 %
Manifold Absolute Pressure 9.28 PSI
Trim Position 0 #
Baro Pressure 14.05 PSI
Trim Volts 0.00 VDC
Manifold Air Temperature 100.40 °F
Pitot ADC 0 #
Oil Pressure 53.32 PSI
Paddle Wheel 0 Hz
Throttle Position 0.12 %
Sensor Power 4.99 VDC
Throttle Sensor Voltage 0.55 VDC
Lake/Sea Temp 404.60 °F
Spark Advance -6.06 DEG
Fuel Level 1022 #
Battery Voltage 13.87 VDC
3. TROUBLE CODE STATUS
Current ECM Codes
Sensor Fault, click Read Fault button for details
Trouble Code List:
SEA PUMP CKT HI Code is active
PITOT CKT LO Code is active
STEER CKT HI Code is active
TRIM CKT LO Code is active
Freeze Frame Data:
0 STEER CKT HI
FF Baro Pressure 14.05 PSI
FF Battery Volts 13.25 VDC
FF Sea Pump Pressure 23.57 PSI
FF Boat Speed 0.00 #
FF Manifold Air Temp 95.00 °F
FF Coolant Temp 140.00 °F
FF Demand 0.00 %
FF Engine Speed 0 RPM
FF Engine State Stall
FF FPC Total 0.0 Counts
FF Frequency Count 371
FF Fuel Level 0.00 %
FF Gear Position In Gear
FF Lake Temp 404.60 °F
FF Engine Load 0.00 %
FF Main Pwr Relay Requests 4.0
FF Manifold Air Pressure 14.06 PSI
FF Oil Level 0.00 %
FF Port Tab Pos 0.00 %
FF Available Power 100 %
FF Run Time 32.63 hrs
FF Starboard Tab Pos 0.00 %
FF TPS Percent 0.00 %
FF Trim Position 0.00 %
1 TRIM CKT LO
FF Battery Volts 13.22 VDC
FF Sea Pump Pressure 35.48 PSI
FF Demand 0.00 %
FF Frequency Count 310
FF Oil Level 0.00 %
FF Available Power 90 %
2 PITOT CKT LO
FF Battery Volts 13.19 VDC
FF Sea Pump Pressure 35.77 PSI
FF Demand 0.00 %
FF Frequency Count 316
FF Oil Level 0.00 %
3 OVERSPEED
FF Baro Pressure 14.42 PSI
FF Battery Volts 13.30 VDC
FF Sea Pump Pressure 3.49 PSI
FF Boat Speed 174.00 #
FF Manifold Air Temp 80.60 °F
FF Coolant Temp 80.60 °F
FF Demand 46.96 %
FF Engine Speed 4970 RPM
FF Engine State Running
FF FPC Total 72.8 Counts
FF Frequency Count 1
FF Engine Load 24.62 %
FF Main Pwr Relay Requests 1044.0
FF Manifold Air Pressure 9.85 PSI
FF Oil Level 0.00 %
FF Available Power 7 %
FF Run Time 11.17 hrs
FF TPS Percent 46.96 %
4 MPRLY OUTPUT
FF Baro Pressure 14.50 PSI
FF Battery Volts 6.02 VDC
FF Sea Pump Pressure 0.00 PSI
FF Manifold Air Temp 64.40 °F
FF Coolant Temp 64.40 °F
FF Demand 0.00 %
FF Lake Temp 402.80 °F
FF Manifold Air Pressure 14.50 PSI
FF Oil Level 0.00 %
FF Available Power 0 %
FF Run Time 10.98 hrs
5 PRT EMCT OVRHT
FF Baro Pressure 14.48 PSI
FF Battery Volts 12.44 VDC
FF Sea Pump Pressure 0.28 PSI
FF Manifold Air Temp 114.80 °F
FF Coolant Temp 186.80 °F
FF Demand 0.00 %
FF Lake Temp 406.40 °F
FF Manifold Air Pressure 14.48 PSI
FF Oil Level 0.00 %
FF Available Power 6 %
FF Run Time 11.40 hrs
6 LOW DRIVE LUBE
FF Baro Pressure 14.57 PSI
FF Battery Volts 13.14 VDC
FF Manifold Air Temp 32.00 °F
FF Coolant Temp 28.40 °F
FF Demand 0.00 %
FF Manifold Air Pressure 14.55 PSI
FF Oil Level 0.00 %
7 STB EMCT OVRHT
FF Baro Pressure 14.00 PSI
FF Battery Volts 14.16 VDC
FF Sea Pump Pressure 0.55 PSI
FF Boat Speed 95.00 #
FF Manifold Air Temp 82.40 °F
FF Coolant Temp 134.60 °F
FF Demand 8.73 %
FF Engine Speed 1105 RPM
FF FPC Total 32.1 Counts
FF Frequency Count 0
FF Engine Load 10.03 %
FF Manifold Air Pressure 8.05 PSI
FF Oil Level 0.00 %
FF Run Time 11.45 hrs
FF TPS Percent 8.73 %
8 SEA PUMP CKT HI
FF Sea Pump Pressure 31.84 PSI
FF Demand 0.00 %
FF Frequency Count 89
FF Oil Level 0.00 %
9 GUARDIAN
FF Baro Pressure 14.22 PSI
FF Battery Volts 14.08 VDC
FF Sea Pump Pressure 42.89 PSI
FF Boat Speed 76.00 #
FF Manifold Air Temp 132.80 °F
FF Coolant Temp 156.20 °F
FF Demand 98.48 %
FF Engine Speed 4597 RPM
FF FPC Total 78.8 Counts
FF Engine Load 35.83 %
FF Manifold Air Pressure 13.73 PSI
FF Oil Level 0.00 %
FF Run Time 31.28 hrs
FF TPS Percent 98.48 %
Fault Log Data
Fault Descriptions Seconds
Battery Range High: 0
Battery Range Low: 0
Block Pressure is Low: 0
Compressor Temp Overheat: 0
ETC Motor Open: 0
ETC Motor Short: 0
Fuel Pressure Sensor Input High: 0
Fuel Pressure Sensor Input Low: 0
Guardian Strategy: 12
Knock Sensor 1: 0
Knock Sensor 2: 0
Low Oil Pressure Strategy: 0
Low Oil Remote Strategy: 0
Low Oil Reserve Strategy: 0
MAP Sensor 1 Input High: 0
MAP Sensor 1 Input Low: 0
MAP Sensor 1 Idle Rational: 0
Oil Pump Output: 0
Overspeed: 0
Port Clnt Overheat: 0
Starboard Clnt Overheat: 0
Warning Horn Output: 0
Water In Fuel: 0
Engine Run Time History:
Total engine run time: 32.65 Hours
0 - 749 RPM: 17.03 Hours
750 - 1499 RPM: 4.35 Hours
1500 - 2999 RPM: 5.02 Hours
3000 - 3499 RPM: 2.37 Hours
3500 - 3999 RPM: 1.87 Hours
4000 - 4499 RPM: 1.77 Hours
4500 - 4999 RPM: 0.25 Hours
5000 - 5499 RPM: 0.00 Hours
Over 5499 RPM: 0.00 Hours
Member of the Liquid Jungle
hp500efi is offline
Old 08-30-2006 | 06:58 PM
hp500efi's Avatar
Member #9
Default Re: Scan results....need help
BTW, before the beeps, I did have a bad seawater impeller that did result in an alarm of overheat...that impeller was changed and ran fine until the cable broke. If there is a code indicating overheating, that was when the impeller was bad and was probably in the code history. But that was fixed.
hp500efi is offline
Old 08-30-2006 | 08:43 PM
You are running in guardian-90 %-since you didnt give specs on the boat -you have codes indicating that you have issues with your transom harness-If you arent using transom harness than the codes that you get for pitot,steering and trim are normal codes and they will always show up on code history-however the reason you are being limited to 90 % and running in guardian is that you have a code for seawater pump circuit high
mr mercruiser is offline
Old 08-30-2006 | 08:49 PM
you should check all connections at sea water pump and look at the connection good-also I dont know what type of boat you are running but by the looks of things you have more run time 1500 to 2900 rpm's that at any other rpm range-did you buy this boat to idle around or are you gonna start running with the dogs!! jam the throttles forward brother or could it be the boats tooooooooo fast for ya??
Old 08-30-2006 | 08:50 PM
Dave_N's Avatar
SEA PUMP CKT HI
Thats the one thats causing your alarm. CKT HI is usually due to open circuit. Start by checking the connector at the sensor for bent pins, water, ect.
Dave
Dave_N is offline
Old 08-30-2006 | 08:56 PM
Dave_N's Avatar
I don't see any evidence of "trouble with the transom harness".
Dave_N is offline
Old 08-31-2006 | 06:58 AM
hp500efi's Avatar
Member #9
Originally Posted by Dave_N
SEA PUMP CKT HI
Dave
Dave, are you talking about the sensor attached to the pump housing that senses water temperature? If so, I know what to look for.
Oh, and is the motor in the 90% Guardian mode? if so, can I erase the fault codes to get it back to 100%?
Thanks much!!
Jeff
hp500efi is offline
Old 08-31-2006 | 07:43 AM
SB
Damn - I guess swimming is out of the question !
Just making a funny. Sorry - carry on.
SB is offline
Old 08-31-2006 | 08:50 AM
Dave_N's Avatar
The sensor on the pump is the Sea Water Pressure Sensor. Thats the one you want to check.
Yes, you are at 90% available power, but you can't just clear the code. A fault code that is "Active" is due to the sensor being currently out of range. Even if you could clear it, the fault would reset immediately.
Dave
Dave_N is offline
Old 08-31-2006 | 12:44 PM
Official OSO boat whore
Sounds to me like the engine is going bad. I'll give you $50 and take the problems away tonight.
Cord is offline
