exhaust help can i run my pipes this way >
Old 09-01-2006 | 11:08 AM
nocigarette's Avatar
Default exhaust help can i run my pipes this way
can i run my pipes up hill when dry with my inner tubes (water)extending 1/2 past the tail..........
Attached Thumbnails exhaust help can i run my pipes this way-magnum-029.jpg   exhaust help can i run my pipes this way-magnum-030.jpg   exhaust help can i run my pipes this way-magnum-028.jpg
nocigarette is offline
Old 09-01-2006 | 11:18 AM
dean51267's Avatar
Default Re: exhaust help can i run my pipes this way
probably be okay, until a back wash comes over the back of the boat, and you know at SOME point this is going to happen, schite always does, and then you stand a good possability of injestion and hydrolocing a cylinder..........
I am not an expert, but that would freak me out...........
dean51267 is offline
Old 09-01-2006 | 11:22 AM
i am having on puck of a time getting them to hit my old holes so i rolled them up to see what it would look like..............if i run them out the old holes they will sit about a 3/4 of a inch in the water and backing up scares the pee out of me.....
Old 09-01-2006 | 11:45 AM
SB
It looks like your water discharge tubes are inside those tails, so I would say don't do it.
SB is offline
Old 09-01-2006 | 11:48 AM
Too Old's Avatar
Are they wet?
Too Old is offline
Old 09-01-2006 | 02:07 PM
no they are dry with the tubes on the inside of the pipe but the water discharge sticks past the end a half inch
Old 09-01-2006 | 02:55 PM
I think that it's a bad idea. My main concern isn't with reversion, it's with water finding its way into the pipe whether the engine is running or not. Rain may be a problem. Water coming over the stern in the event of an engine shutdown while you're running will probably be a big problem. If you are going to have to patch the bravo holes anyway, route the pipes to a downhill location through the transom. Just my 2 cents,
Rene
oldandtired is offline
Old 09-02-2006 | 04:39 AM
cig1988's Avatar
Bad idea with that set up in my opinion.
cig1988 is offline
Old 09-02-2006 | 09:54 AM
Looks LOUD!!
Pure Energy is offline
Old 09-02-2006 | 10:09 AM
zt260's Avatar
If you put turn downs on it will work. Otherwise bad idea.
zt260 is offline
