Engine Internals/Components >
Old 09-08-2006 | 08:57 PM
Elite Marine's Avatar
Default Engine Internals/Components
I'm planning on using the following for my 540, M-3 Procharger Build:
Merlin lll block (not sure if I am going 9.8 or 10.2 deck yet)
AFR 315 Heads CNC Ported, Assembled
Callies or Lunati Crank
Oliver Rods
JE Blower Pistons 9:1 or so
T&D Shaft Rockers
Billet cam from Bob Madera
Morel Lifters
Hoping to run 800+ at 3 PSI of boost and almost 900 HP at 9 PSI of boost. Konrad ACE Drive and CMI Headers of course!
Im interested in input and proven results from similar builds. Any issues with the above components?
Elite Marine is offline
Old 09-09-2006 | 08:33 AM
Default Re: Engine Internals/Components
CR seems a little high, even the 1075 merc runs only 8.0:1
Pismo10 is offline
Old 09-09-2006 | 10:37 AM
Jesel > T&D
TwinTurboStroker is offline
Old 09-09-2006 | 11:17 AM
he's absolutely right about the cr... 9 to 1 and the next post we see from you will start.. " gee i rolled into the throttles and all of a sudden bthe boat was full of smoke and all the pistons were in the bilge... ..."
stevesxm is offline
Old 09-09-2006 | 11:25 AM
I'm running 8:1 right now and have been told it's a little low. I was told that 8.8:1 is a little better. Anyone else have proven results with thsi set up and what compression are you running?
I don't need to have any issues with the $$ I'm putting into this project!
Carb or EFI?
TxHawk is offline
Old 09-09-2006 | 11:28 AM
Efi
Old 09-09-2006 | 04:23 PM
if you are running a blower then my opinion is anying above 8.5 is asking for trouble unless you are REALLY on your game for fuel and all other monitoring parameters...and you BETTER have the best knock sensor retard system ever made.
stevesxm is offline
Old 09-10-2006 | 08:55 PM
The engine will be dyno'd with O2 sensors and EGTs.
Once in the boat, it will be rechecked and recalibrated with O2 sensors.
Pantera24
8
04-17-2007 05:12 PM
Rexx
7
04-11-2007 11:35 PM
Michael1
02-26-2007 09:20 AM
HOTTZU98
8
08-14-2005 03:06 PM
ROGMAN
0
10-31-2002 10:17 AM
