how hard is to replace the starter
I had a previous question which was titled no start condition, and found out it was ( I think) the starter. I tapped what I think was the starter and the boat started. It looks like a mother f-bomb to get...
The boat is a 92 baja 240 sport.
Thanks again for all the help,
WayneO
WayneO
the local merc dealer here is in the 60's. To change a starter, he pulls the engine out to do it! Does that give you an idea how hard it is ? Or then how old he is ?
if you have to use language like " what i THINK is the starter" then you absolutely need to just hire someone qualified to fix your boat and spend YOUR time doing what you do for a living to earn the cash to pay him. you simply do not have even the most basic skills or knowledge to proceed.
And sometimes, we get it right the 1st time
Regardless, ya gotta learn, right??A while ago I posted a ? here about a potential starter problem. I didn't get ragged on for asking questions. What I did get was helpful feed back from a few members and a few suggestions on where to start and what to look for. That's what this forum is about. No one asks a question just to get a kick in the azz.
Dude,
To change my starter out I have to lean from the other side of the motor with my arms extended out under the starter to get to the bolts. Its a pain in the ARSE. Getting to the wires wasn't the problems but that far bolt under the starter is B****TCH!! And trying to hold the starter when the last bolt is removed so it doesnt drop down into the bilge. I have become a pro at tmine due to shimmming issues of the starter.
and you KNOW what a starter is and what it looks like. there is nothing at all wrong with anyone wanting to learn but GEEZE... do you launch into a technical repair without even knowing what the parts ARE ? thats not even rational.
I grew up in a neighborhood of all Mercedes, BMW's,and Porsche's. It was a 'cut'm a check neighborhood.'
No knowledge at all.
Within 2 yrs of getting my liscense I figured out how to get a small block olds to 7500rpm. The next year I figured out that if I wanted to spin 7500rpm and not break parts every other week that I needed a SBC. A year after that, I figured out that I could build a different motor (BBC) and run faster shifting at a much tamer 6500-7000rpm and do so on pump gas.
So, the question is - can you deal with the wrong decisions, improper R&R, and more costly mistakes at first so you can eventually make more intelligent decisions and do more things on your own ? Or is it not worth the time, effort, and $$$ and have someone else do it ?
Both are fine and respectable to me. Just don't cry about which way you went.
BTW: this is just a starter. Not an engine rebuild or anything. Being a contortionist can be the hardest part of a starter R&R.
I try and do all my own repairs on my boats, I would rather screw it up once and learn then pay somebody else to do it. Ive noticed half the time the marinas have less idea how to diagnosis problems then I do.
all this is true and completely fair enough... you get no argument from me... other than to say...
if it was my 60 k boat and i didn't know my a** from a hole in the ground about working on it... i would hire someone to show me so that i could learn in an intellegent fashion....
in FACT , with roughy 30 yrs experience designing and manufacturing race cars and building engines, that is EXACTLY what i did when i got this top gun w/ two bad motors. i hired a pro to work along side me as i did all the work. he introduced me to the nuances and boat specific technology and techniques so i didn't just light 100 dollar bills on fire by making stupid mistakes. in the end i knew every wire, pipe, and piece of hardware on that boat intimately. it took two weeks.
could i have figured it all out myself ? sure. but why be stupid when you can be smart ?
but thats just me.
but thats just me.
dagah2x -
Found out a trick after all these years. Got it from some 'big truck' mechanics this spring.
Hold the starter up with long zip ties - hung loosely, this way you can swing it under with your arm, finger, what have you, while starting the first bolt.
Worked awesome.
Psyched to be told this trick - just wish I heard / figured it out many years ago. Hell, atleast I founf out now !
Worked awesome.
