Water in Brakeline
Old 09-14-2006 | 08:25 AM
aquatictherapy's Avatar
Default Water in Brakeline
On my ski boat trailer I noticed the surge brakes pushing back further than normal. I opened the brake fluid res. and noticed water. What do I need to do, just drain, refill and bleed? Anything else. Thanks all. Scott
aquatictherapy is offline
Old 09-14-2006 | 09:02 AM
ratman's Avatar
Default Re: Water in Brakeline
that should do it. make sure that the res cap fit tight and water is not entering the system from the cap not sealing well. good luck, rm
ratman is offline
Old 09-14-2006 | 10:15 AM
Wobble's Avatar
SORE MEMBER
What Ratman said + make sure you flush some fluid all the way through the system as brake fluid tends to absorb water and you need to get all of it out.
Wobble is offline
zimm17
8
07-10-2007 09:09 PM
MnHowardCat
7
05-29-2007 10:12 PM
waterbum
0
08-15-2005 10:36 AM
28Eliminator
11
06-22-2004 10:43 PM
Waterfoul
04-17-2003 08:01 PM
