outdrive anode >
outdrive anode
outdrive anode
Old 09-14-2006 | 08:40 PM
Default outdrive anode
What does everyone have? A flat one or one with a bit of a skeg like mine (see pic)?
ECeptor is offline
Old 09-14-2006 | 08:49 PM
Rebel_Heart's Avatar
Default Re: outdrive anode
Flat. My '93 had a skeg like that.
Rebel_Heart is offline
Old 09-14-2006 | 09:12 PM
I should have mentioned my boat is a 24' single BBC.
ECeptor is offline
Old 09-14-2006 | 10:42 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Mine have been the flat ones.
I was under the impression the 'skeg type' anodes are for the non power steering boats to help offset any torque??
US1 Fountain is offline
Old 09-15-2006 | 06:49 AM
DURANGOKID59's Avatar
What is the anode there for, whats its function?
DURANGOKID59 is offline
Old 09-15-2006 | 08:19 AM
The anodes are sacrifical. They will rot out before the actual metal in your outdrive. There are two types one set for salt water and one set for fresh water. The one in the picture is not the only one on your drive. You have a flat plate on the bottom of the transom and two bolts under the drive. Check them monthly if you keep your boat in the water. Easy replacement. Also, I believe the earlier post is correct, the skeg version shown is now only placed on drives without power steering.
MC-BOYS is offline
Old 09-15-2006 | 09:14 AM
My boat has powersteering, but not external hydraulic. should I get one without the skeg? I assume it would be a little more efficient without the skeg.
ECeptor is offline
Old 09-15-2006 | 09:21 AM
zt260's Avatar
Flat one is still recommended.
zt260 is offline
Strip Poker 388
Swap Shop
4
10-06-2008 05:45 PM
littledcsrodshop
03-28-2007 08:39 AM
Rippem
2
06-03-2005 06:11 AM
fty
1
10-08-2004 06:45 AM
