Would you Tie down your boat this way ?? >
Old 09-15-2006 | 12:09 AM
Strip Poker 388's Avatar
Rob
Question Would you Tie down your boat this way ??
It would have to scratch it Why not hook it to the eye?
I guess at least he has straps on it.
Attached Thumbnails Would you Tie down your boat this way ??-destin-poker-run-8-19-06-011-medium-.jpg   Would you Tie down your boat this way ??-destin-poker-run-8-19-06-010-medium-.jpg
Strip Poker 388 is offline
Old 09-15-2006 | 12:15 AM
Rob
Default Re: Would you Tie down your boat this way ??
Better?
Attached Thumbnails Would you Tie down your boat this way ??-destin-poker-run-8-19-06-062-large-.jpg
Old 09-15-2006 | 12:16 AM
Outdrive1's Avatar
Masher touches my
takes all kinds.........
Outdrive1 is offline
Old 09-15-2006 | 06:38 AM
Registered User
Originally Posted by Strip Poker 388
Better?
No.
Strapping 90 degrees off the direction of movement is a waste of time. If you had a problem, the boat would still move. Those straps are rated for a static load, not dynamic. Once the boat started moving, it wouldn't stop. Those straps would pop in a heartbeat.
Chris Sunkin is offline
Old 09-15-2006 | 07:02 AM
el indio's Avatar
try this!!!!!!!!!!!!!!!!!!!!!!!!!
el indio is offline
Old 09-15-2006 | 07:13 AM
itilldo's Avatar
I think there's room for a few more straps
itilldo is offline
Old 09-15-2006 | 07:46 AM
ratman's Avatar
i do it over the nose like that but use 3/8 chain so it wont break it is a little tuff on the paint.
mm, do you own stock in the strap co???
ratman is offline
Old 09-15-2006 | 08:00 AM
gotime34's Avatar
I think that guy is a member on here...maybe he'll chime in and give his reasoning.
gotime34 is offline
Old 09-15-2006 | 08:01 AM
Registered User
That works.
...If the bow eye is reinforced properly. I've seen a couple that have torn out. No backing plate.
Old 09-15-2006 | 08:03 AM
i know i'm goinig to get sh=t for this one.the boat is fine he's supporting the rocket trailer so it does not flex
sonic28 is offline
