Need info changing from Carbed to Injected? >
Old 09-15-2006 | 01:43 PM
Default Need info changing from Carbed to Injected?
Here the question:
I currently have a 454 Mag 1991 Carbed.
Would like to make it fuel injected, have a connection to a fuel injection system off of a 1996 502 Mag EFI(includes fuel system/wire harness/ecu/ignition/manifold, basically everything)
would this be somewhat a direct bolt on to my current engine, and would it run correctly? Is it worth the effort? Would I expect to see any HP gains?
Any input would be greatly appreciated.
yamahayz26 is offline
Old 09-15-2006 | 02:47 PM
Default Re: Need info changing from Carbed to Injected?
See my post here:
http://www.offshoreonly.com/forums/s...=139469&page=2
My answer would be no, it's not worth the effort. Especially if you've never done it before. It will drive you nuts and not give you any better results than a proper carb.
Having said that, if you just want to do it for the learning experience, then good luck. It'll be a neat project. Let us know how it comes out.
bcarpman is offline
nocigarette
Wanted
4
09-17-2008 02:31 PM
hoozeyurdaddy
Prop Talk
8
05-24-2008 12:23 PM
tomcat
06-07-2006 06:41 PM
dave54000
2
02-20-2006 08:28 AM
boot
01-31-2005 11:27 PM
