Go Back  Offshoreonly.com > Owners Forum > Sunsation
What's the BEST PROP Agressor 2001 HP500 >
Old 09-17-2006 | 11:04 AM
jeff32's Avatar
Default What's the BEST PROP Agressor 2001 HP500
Just bought that. spinning a Bravo 4 blades 30 pitch at max 4500 rpm, for 73 mph gps. What's the best prop to spin 5000-5100 and more speed? 28 4 blades? What brand?
jeff32 is offline
Old 09-20-2006 | 08:39 PM
Whiteknuckle's Avatar
Default Re: What's the BEST PROP Agressor 2001 HP500
Try a 27 Mirage Plus. I have tried 4 blades on my Rocket and it gives it too much stern lift. This size Sunsation seems to like 3 blade props better. Also you need to get your RPM up around 5200 I would think with a HP 500.
Whiteknuckle is offline
Old 10-05-2006 | 10:00 PM
If the Bravo handles well on the boat, I would think going to a 26" Bravo I would give you another 300-350 RPM and then getting it labbed should net you another 300 RPM, putting you around 5100-5150 which should be ideal for your motor. While a 3 blade will give you the "best" top speed, your cruise speed will suffer as will your ability to get on plane. Steve
509 SC is offline
Old 10-13-2006 | 12:28 PM
Lets keep in mind there that the Agressor is a light narrow boat that responds very well to a bow lifting prop. For years they came from the factory with Mirage 3 blades on them when other style props were available. Getting on plane with an Agressor is not an issue. Lee who is a moderator on the Sunsation page had good luck with a 3 blade Hydromotive Turbo. I have been running a labbed Mirage plus. Just my 2 cents!
Old 10-15-2006 | 09:02 AM
jeff32's Avatar
We tried a maximus (26 or 27 can't remember) Pushed the speed needle down the bottom of the gauge,even a little bit more, and the max on gauge is 80! Maybe a real 77-79 GPS... happy with the result!
jeff32 is offline
Old 10-18-2006 | 03:24 PM
Dave M's Avatar
Veteran: Navy
I have a 24 Superboat, very similar hull to the Agressor. I run a 28P Bravo 1. The boat came with a Mirage+ and the handling was terrible. The Bravo 1 made a HUGE handling difference. Top speed was pretty much the same and mid range speeds were much better.
Dave M is offline
Old 10-20-2006 | 05:52 PM
Sydwayz's Avatar
Forum Regulator
I'd try a labbed 28P Bravo 1 4-blade.
Sydwayz is offline
Old 10-28-2006 | 07:34 PM
jeff32's Avatar
yeah... but next summer!
jeff32 is offline
atthelake27
Sunsation
8
07-12-2007 05:54 PM
lulu
Prop Talk
6
09-20-2006 05:48 PM
lulu
09-05-2006 07:20 PM
hammer01
Baja
10
04-15-2006 11:24 AM
SMOKE THIS
08-04-2003 02:07 PM
