Water pressure guage question for 496HO >
Old 09-17-2006 | 08:55 PM
Default Water pressure guage question for 496HO
Any one know what is the recommended numbers on water pressure for 496HOs?. Ran my boat 3 weeks ago and saw that water pressure gauge on my port side is high than my starboard side after 2500 RPM. When running @ 4000 port side gauge constantly changing betwwen 22 to 27 and starboard shown steady @ 20. Any thing I can do to check?
Donzi35ZR is offline
Old 09-17-2006 | 10:02 PM
Default Re: Water pressure guage question for 496HO
Blocks get crap in them,sand,mud,iron rust deposits from the block itself,this can cause a blockage and cause inaccurate readings.The 496 should have closed loop cooling but water still has to enter some where inorder to show pressure!Find the exit water line and back flush meaning were the water would exits the boat,put a garden hose there and flush everthing back out!
JJONES is offline
Old 09-17-2006 | 10:10 PM
maybe impeller missing 1 of those fins???
dualprop is offline
Old 09-18-2006 | 06:33 AM
Dave M's Avatar
Veteran: Navy
I can't explain the difference in the two motors. But, even the 20 PSI doesn't seem out of line. At 4000 RPMs, I'm running less than 20 psi. From my Diacom scans, I'm showing a peak of about 23 psi, that's including WOT, 5000 rpms.
Dave M is offline
Old 09-18-2006 | 12:36 PM
Wink Re: Water pressure guage question for 496HO
The raw water feed routing is different on the port side than the starboard side and the pressures will always run slightly different than each other. The pressure numbers you are seeing seem to be within the standard operating range and if you had any real issues like restricted flow and overheating the temperature sensors on each manifold would send an overtemp signal to the ECM and your Guardian system would beep and indicate a temperature fault condtion of exhaust water temperature high.
Ray @ Raylar
Raylar is offline
Old 09-18-2006 | 04:16 PM
boatfreak's Avatar
I've never tried to track down the lines and ports but my 01 496ho that has just turned 300 hrs has run over 35 lbs since it was new. It pegs the gauge after about 3500 rpms.
boatfreak is offline
dicdik
Do It Yourself, Boating on a Budget
4
07-09-2008 02:28 PM
RedDog382
08-06-2007 09:16 PM
ls1nova
8
06-13-2007 09:27 AM
35 White Lightning
Fountain
6
09-06-2005 01:50 PM
scottsumrall
16
08-20-2002 11:26 PM
