no oil psi no knock >
no oil psi no knock
no oil psi no knock
Old 09-18-2006 | 06:45 PM
Cool no oil psi no knock
6-7 psi oil pressure no knocking yet!!!! at WOT 20-25 psi.. what do you think it could be?
osen007 is offline
Old 09-18-2006 | 06:58 PM
Lofty's Avatar
Default Re: no oil psi no knock
Could be a bad sending unit. If the diaphragm leaks it will give low readings. Try running a mechanical guage. We test them by running a mechanical guage up to the back seat, have someone give you the readings. If you wait to hear knocking it's too late.
Lofty is offline
Old 09-18-2006 | 07:36 PM
I keep a mechanical gauge in my tool box. Just get a cheep one from the auto parts store. If your mains are going out you do not want to keep running it.
jeffswav is offline
Old 09-18-2006 | 07:43 PM
Ditto, I got scared a couple years back with no pressure and the sender was bad......I think the spring that holds back diaphragm breaks/weakens.
happy hours is offline
Old 09-19-2006 | 08:45 AM
that is on a mechanical gauge
osen007 is offline
Old 09-19-2006 | 09:32 AM
Pickup tube? I would not be running the engine until I found out the problem.
1BIGJIM is offline
Old 09-19-2006 | 09:38 AM
gsmith9898's Avatar
change the filter first.
gsmith9898 is offline
Old 09-19-2006 | 12:18 PM
Question Re: no oil psi no knock
We need some more infor here. What motor?, is it new or newly rebuilt? Have you made any changes to filters or coolers? How was oil pressure before and when did this appear? Just not enough info here to give an intelligent opinion here.
Ray @ Raylar
Raylar is offline
Old 09-19-2006 | 05:21 PM
nocigarette's Avatar
I Agree More Info......mech Gauge, Low Oil Pressure. I Would Be Unbolting It And Pulling It......
nocigarette is offline
Old 09-19-2006 | 06:49 PM
Could it be a bad mechanical gauge? Admittedly , I might be well wishing here but is this the second guage to read these pressures? Maybe the gauge is bad.....sure would suk to pull it and disassemble to find that out. I agree with everyone else though if the pressure is accurate pull it and save what you can before it all worst.
