Stern Jack help..... >
Old 09-19-2006 | 07:56 AM
Default Stern Jack help.....
I bought a used Land & Sea stern jack off a late 90's Baja hoping to install it on the 2005 Crownline LPX. both boats have the Bravo 1 drive but my 2005 uses much larger u-joints. so the question is, help me out with what i can do to install the stern jack. my thoughts are too buy the eariler shaft and yoke and have someone make me a yoke or even cut the earlier & newer yoke and weld them back. any thoughts from anyone???? i know the jack works wonders on my hull design so i'm very eager to make it work. and i need a winter project as well......
bmergner is offline
Old 09-19-2006 | 08:05 AM
Default Re: Stern Jack help.....
Call Land and sea and see if they can help. I have one on my Baja and It performs very well. I hope you got the shift cable also, That sob was $150!
kennyo is offline
Old 09-19-2006 | 10:36 AM
You should sell the Stern Jack and buy a set of oars! Either way, you won't catch me .
Sorry bro, I couldn't resist! Welcome to OSO.
Plane Silly is offline
Old 09-19-2006 | 12:24 PM
i tired land and sea already nd NO LUCK at all. there are semi out of business and offered nothing for help si i'm on my own. i would buy some paddles if i could row them and drive at the sametime anything for more MPH
bmergner is offline
Old 09-19-2006 | 12:46 PM
SB
Land and Sea only cares about dynos, but they don't seem to care much about their dyno's. Weird, huh ?
SB is offline
Old 09-20-2006 | 09:31 AM
mcollinstn's Avatar
Tryin to remember how the intermediate shaft works in those things...
Does it have its OWN input shaft and yoke?
Can't picture it in my head, but you might could use some "adaptor" U joints with one side bigger than the other.
Will try to get a better mental image so I can help.
mc
mcollinstn is offline
Old 09-20-2006 | 09:51 AM
Hey Brett, I just realized you need the yoke that goes into the SJ on the drive side modified. You can buy an earlier model yoke and socket assy for the coupler side. See if you can post some pictures. I'm sure someone on here can come up with a solution. I bet there is an adapter type ujoint that would work. Finding it will be the problem. How about buying a late model stub shaft and having a drive shaft shop cut the end off and weld the SJ end to it. Seems like it would work if done correctly.
bobl is offline
Old 09-20-2006 | 08:06 PM
i think that's what i may have to try and do. i plan to pull the drive in the next few weeks and make it a winter project. that might be the only way...... once i have my drive here at the house i can start to measure and start chasing some parts. i may even buy a different drive and sell mine if i have tooooooooo. i know the stern jack works so i'm open to do anything at this point.
Bob, do you know if the splines are different on the end of the driveshaft?
bmergner is offline
Old 03-05-2025 | 11:34 AM
bbm
Good afternoon SB. I was wondering if you still have the installation instructions for an Alpha sternjack.
Thank you
bbm is offline
Old 03-05-2025 | 12:26 PM
SB
Omg, i’m 19yrs older, just like that. Wtf ?
I think I do. Give me a day to find them, if i still have them. Pm me your e-mail address so i can forward them.
SB is offline
