Quality of ride 36 Baja vs. 35 Fountain >
Old 09-23-2006 | 04:40 PM
mpally's Avatar
Default Quality of ride 36 Baja vs. 35 Fountain
Which one is a better ride in rough water? The quality of ride is #1. I know that this isn't comparing the same size boats, but has anyone rode in both? What about a 38 Fountain compared to the 36 Outlaw?
mpally is offline
Old 09-23-2006 | 04:51 PM
Default Re: Quality of ride 36 Baja vs. 35 Fountain
36 baja is a way better ride than a 35 Fountain. The fountain will be faster. Both buddy's had each one. So I speak from experience.
baja27 is offline
Old 09-23-2006 | 04:54 PM
FeverMike's Avatar
36 Baja will cut through the rough better and is much easier to drive. With the 36 Baja traditonal 24 degree bottom the boat will be slower but more cushioned in the rough.
FeverMike is offline
Old 09-23-2006 | 05:02 PM
TeamSaris's Avatar
Driver-441
Racer
go for the beak in this case
TeamSaris is offline
Old 09-23-2006 | 05:05 PM
FeverMike's Avatar
The Fountain is better built and much more solid but in rough water the 36 hull Baja is a bigger hull than the 35 Fountain (around a 32' hull minus the platform) and the Baja has 2 more degrees deadrise at the transom
Old 09-23-2006 | 05:11 PM
had a 36 outlaw with 496 ho's it handled loto water very well, could run 50-55mph with tab down thru some pretty nasty water, great boat for the money.
Buddy OO is offline
Old 09-23-2006 | 05:23 PM
29goingon42's Avatar
I agree, Ur not going to win any races but the ride will be very stable.
If you can be happy in the 60's . I drove a 38 through alot of slop at LOTO and it felt the same as a 36. Never drove a 35.
Alot of boat for the money is very true.
29goingon42 is offline
Old 09-23-2006 | 05:56 PM
mpally's Avatar
Can you expand on this a bit?
mpally is offline
Old 09-23-2006 | 05:57 PM
mpally's Avatar
What is the top speed with this setup? I think the 500efi's are a better match. That should run mid 70's right?
mpally is offline
Old 09-23-2006 | 08:39 PM
boat ran 70 with the 496 ho's the 500's will run 73-74.
Buddy OO is offline
