Go Back  Offshoreonly.com > General Discussion > Boating Safety
Do you always wear your kill switch lanyard? >
View Poll Results: Do you wear your kill switch lanyard
All the time
136
43.17%
Some of the time
118
37.46%
Never
61
19.37%
Voters: 315. You may not vote on this poll
Old 09-24-2006 | 07:35 PM
bcschoe's Avatar
BRAD SCHOENWALD
Default Do you always wear your kill switch lanyard?
I am really curious about this based on some incidents and other boats I have been a PAX on.
Honest answers please. If you do not, Why not?
bcschoe is offline
Old 09-24-2006 | 07:51 PM
cuda's Avatar
Default Re: Do you always wear your kill switch lanyard?
I always wear it when on a plane, unless I forget. Speaking of kill switches, we took out the Minx today. When we got home, I was running the boat, and decided to test the kill switch. I pulled it and the boat kept running! I don't know if it's the switch, or wasn't wired properly, but I have a brand new one here at the house that I will install this week.
cuda is offline
Old 09-24-2006 | 07:58 PM
R Addiction's Avatar
AT Cult Member #3
Always hook it up...and yes it does work!!
R Addiction is offline
Old 09-24-2006 | 08:23 PM
bcschoe's Avatar
BRAD SCHOENWALD
Cuda,
Good point I'm glad you brought this up. As part of our daliy checks we always shut the boats down by using the kill switch. I check my own boat by using it when I shut down after flushing the motors.
The "unless I forget" is one thing I'm trying to mitigate.
bcschoe is offline
Old 09-25-2006 | 06:36 AM
cuda's Avatar
Originally Posted by bcschoe
Cuda,
That's a good idea, shutting them down by pulling the kill switch. If you left them pulled, it would also remind you to put it back on the next time out. Either that, or tear the engine completely down because it won't start.
cuda is offline
Old 09-25-2006 | 09:32 AM
lucky strike's Avatar
I use mine when on plane
lucky strike is offline
Old 09-25-2006 | 10:37 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Absolutely always.
Sydwayz is offline
Old 09-25-2006 | 11:09 AM
Indy's Avatar
Member #154
Originally Posted by Sydwayz
Absolutely always.
Ditto...no excuse not to.
Indy is offline
Old 09-25-2006 | 11:49 AM
ericaull's Avatar
I use mine when out alone. (should do it all the time)
ericaull is offline
Old 09-25-2006 | 02:50 PM
Downtown42's Avatar
Anything over 30-40mph yes.
Downtown42 is offline
