middle floor board rotted >
Old 09-30-2006 | 03:00 PM
Default middle floor board rotted
My 92 baja 240 middle floor board is rotted out. I just picked up the boat this past summer. Is this an indication the boat may have taken on some H2O ?? The old floor was coated with fiberglass, can I just replace with marine ply ?
ippon is offline
Old 09-30-2006 | 03:06 PM
el indio's Avatar
Default Re: middle floor board rotted
Put in new carpet and sell it...............
el indio is offline
Old 09-30-2006 | 03:15 PM
Probably just had a crappy or no cover on it for an extended period of time. Recoat it with resin if you want it to last.
Griff is offline
Old 09-30-2006 | 03:20 PM
Dtile's Avatar
I have had many boats over the years have rotten wood.... I use http://www.rotdoctor.com/ CPES will help out alot, along with thier resin
I use CPES on all wood, turns it into almost rock even if its rotten...
dont know whats in his mix but use a mask!
Dtile is offline
Old 09-30-2006 | 10:44 PM
AIR TIME's Avatar
Been there went shaped out new piece of m/p I hit it with2layers of glass and add stringers to it real small 2x4 its sweet now been 4yrs mines a 88 doing new full height bulkheads this winter and back seat. art
AIR TIME is offline
Old 10-01-2006 | 09:01 PM
Yep, happended to my 1991 boat as well a few years ago. Moisture just built up over time and use and the wood rotted. It was not marine plywood....... I cut it our and replaced it with marine plywood coated on both sides with glass and resin. Should be good for about 83 years or so! Solid as a rock.
stevel is offline
alecsammy
11
11-04-2006 03:57 PM
bryanspeedracer
71
10-11-2006 03:29 PM
kmiller
37
07-22-2004 09:23 PM
bryanspeedracer
Fountain
9
07-02-2004 08:55 PM
HOTTZU98
5
06-19-2004 09:16 PM
