Go Back  Offshoreonly.com > Owners Forum > Sonic
winterizing sinks ? >
winterizing sinks ?
winterizing sinks ?
Old 09-30-2006 | 05:42 PM
26sonic's Avatar
Default winterizing sinks ?
turned on water pump and drained cabin sink and head sink and transom shower, put about 4 gallons of anti freeze (pink stuff) in fresh water fill tank, turned on water pump again and turned on cabin sink but nothing is coming out ? did the pump loose it's prime ? any ideas?
26sonic is offline
Old 09-30-2006 | 06:40 PM
Default Re: winterizing sinks ?
can you hear the motor?if not tap it lighly.also check in line fuse.
sonic28 is offline
Old 09-30-2006 | 07:38 PM
26sonic's Avatar
motor is running fine.
26sonic is offline
Old 10-01-2006 | 07:24 AM
Sonic30ss's Avatar
Is there an inline filter before the pump inlet?
Sonic30ss is offline
Old 10-01-2006 | 05:12 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It is possible. Try pressurizing the fresh water tank. Try hooking up a powerful shop vacuum on the and blowing air into the tank from the fill location, and turn on the water pump.
If you know where the water pump is, disconnect the inlet from the tank, and lower it into the bilge, as long as it is 'downhill' from the tank, it should flow AF freely. If not, try this while blowing into the tank with the shop vac.
Sydwayz is offline
Old 10-05-2006 | 07:39 PM
bn
Hey Tony,
Looks like you lost the prime in the water system. There is a fix and it's pretty easy when you just want to refill with water. But since you are winterizing and don't want to waste all that AF, try having someone pour another bottle of antifreeze down the fill hole and then while they are pouring, you run the transom shower to pull the AF through and reprime it.
If that doesn't work, wrap a rag around the garden hose nozzle, turn it on high and stuff it in the fill hole while trying to make a seal around the fill hole. Then have someone turn on one of the sinks or the transom shower. You are trying to push the water in with enough force to prime the pump again.
Then you will have to drain the water again and put more AF in. DON'T drain ALL of the water out. Stop when you hear it about to start sputtering.
Good luck,
Brian
bn is offline
Old 10-08-2006 | 01:08 AM
That's exactly what I was going to say!
frankenstein is offline
kitten
01-09-2008 02:57 PM
26sonic
09-30-2006 08:55 PM
26sonic
2
09-28-2006 07:21 PM
bajabob38
12-07-2002 03:12 PM
