I did it to myself and now I need help selecting injectors and fuel mapping >
Old 10-01-2006 | 01:58 PM
Default I did it to myself and now I need help selecting injectors and fuel mapping
I have a 7.4MPI with a 5PSI M1 Procharger, Merlin heads, Gill exhaust, Mag internals, roller rockers, STOCK INJECTORS and detonation problems. Mark @ Performance is a master and he warned me that my injectors might not provide enough flow to feed the 2.25 inch intakes. He re-programed my ECU for 90% duty cycle @ WOT and it worked good for most of the summer, however I recently detonated @ sea level and now I am re-building plus changing to bigger injectors. The motor seemed to run ok @ WOT on Lake Tahoe (6229msl). Sea level WOT called for more fuel and I just could not get enough through the stock injectors and leaned out causing the detonation. The question is what flow do I have in the stock injectors and what should I go to for correct delivery @ sea level? I also have the Procharger fuel system for a 7.4 MPI (stock pump fed by the red in-line vein pump). I do see 60PSI with the stock injectors while adjusting regulation down to 54#s @ WOT. Should I modify delivery pumps as well? I will have to re-map. Should I get an on board tuner person? Are their any on the west coast?
baronbob is offline
Old 10-01-2006 | 03:31 PM
Default Re: I did it to myself and now I need help selecting injectors and fuel mapping
Talk to Arizna Speed and Marine (a tech not a counter guy) and they can set you up with injectors and the remap make sure you get their o-rings for the injectors. I have a similar setup, fuel pressure at idle is 36#'s and rises about 80#'s at WOT.
RBeyer is offline
Old 10-01-2006 | 05:09 PM
Im running the 50lb injectors with an M1 on a 502. They came from Arizona marine. Also an aeromotive fuel pump and regulator with larger supply lines. Call them and ask about a 2 bar map sensor also. My computer was done by them and its a little rich, I plan to have it remapped on the water, its the only way to get it right....
Mine as well do it the right way now and not have to worry....
dagah2x is offline
Old 10-01-2006 | 06:55 PM
A little rich is a good thing. It beats the alternative. I'd rather clean a little black than Kaboom!!!!
RBeyer is offline
Old 10-01-2006 | 08:09 PM
Elite Marine's Avatar
What HP do you think the engine is capable of producing? What happened to your knock sensor? It should have put the ECU in safe mode or actually retard timing to stop the knock!!
I ran 42# Injectors for 5 years in a similar set up with no issues at all.
You definately need the Aeromotive Pump or equal and larger lines.
What size is your supply from the tank?
There are several potential issues here and I'm sure that we can sort through them one at a time and prevent this from occuring again!
Kirk
Elite Marine is offline
Old 10-01-2006 | 09:34 PM
If memory serves me correctly the stock 7.4MPI injectors are something like 24 lbs. It's no wonder you leaned it out!
bobl is offline
Old 10-01-2006 | 10:01 PM
I would guess the HP to be 500+. The fuel delivery is stock Merc, I would guess 5/16". The knock sensors went off twice and the first caused #6 compression to go from 130#s to 90 and then declined over the summer. After the second knock sensor happening I believe I can see piston damage to #6. I have fuel cool does that have to change also?
baronbob is offline
Old 10-03-2006 | 11:01 PM
Strip Poker 388's Avatar
Rob
I would ck with Mark at Precision Marine .You normaly do not want to go over 80% duty cycle,bandaids usally will get ya introuble ,just think when your over the 80% and a fuel pump gets a little week, voltage drop or fuel filter gets cloged a little ,or a bad batch of fuel not much fail safe there.
Strip Poker 388 is offline
Turbojack
07-10-2008 08:35 PM
kennyo
0
07-30-2007 03:01 PM
kennyo
4
05-04-2005 01:02 AM
50boat
4
04-04-2005 09:52 PM
Jeff Pierpont
0
03-25-2004 07:38 PM
