Your Opinions please.......
Old 10-03-2006 | 12:01 AM
2112's Avatar
Default Your Opinions please.......
Saw this interesting idea recently. I have done airbags and load distibution bars. Pros and cons for both.
This looks simple and easy.
Found it at www.hell-ya.com
Attached Thumbnails Your Opinions please.......-dsc05956largepict.jpg   Your Opinions please.......-duallylarge.jpg
2112 is offline
Old 10-03-2006 | 06:21 AM
Wobble's Avatar
SORE MEMBER
Default Re: Your Opinions please.......
I think that would be a bad idea, it does nothing to stabilize the vehicle side to side and in an extreme situation could maybe unload the rear suspension.
It's an interesting idea.
Wobble is offline
Old 10-03-2006 | 06:38 AM
offshoredrillin's Avatar
I could see it doing as Mark says, descending a steep hill, if the trailer hitch scrapes on some of them, it would totally take the rearend off the ground, then all that weight would have the potential to free roll. Good to see people thinking though.
offshoredrillin is offline
Old 10-03-2006 | 07:58 AM
BBB725's Avatar
I have seen a similar setup on a horse trailer. The owner said it pulled good, but forget about backing up
BBB725 is offline
Old 10-03-2006 | 08:20 AM
CigDaze's Avatar
I don't know if that's such a great idea.....
Any positive support at that point will act to unload the drive wheels. It will effect braking and handling.
CigDaze is offline
Old 10-03-2006 | 09:35 AM
I believe the original design intention was for RVs that had real crappy tongue weight specs, but owners still wanted to pull a trailer.
Personally I'd rather have as few extra "links in the chain" connecting my tow vehicle to my trailer.
handfulz28 is offline
Old 10-03-2006 | 09:53 AM
Tony Montana's Avatar
The BAD Guy
What happens when the tire(s) blow out at 70mph.
Tony Montana is offline
Old 10-03-2006 | 10:55 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Even their FAQ denotes "this is a temporary fix to a temporary problem".
I can't imagine it would work well with surge brakes either. If you are going around a curve, and hit the brakes, the trailer is going to push the rear of the vehicle sideways. This is already an issue with surge brakes, much less something like this that moves the point of the hitch back what looks to be 12" or so.
Sydwayz is offline
Old 10-03-2006 | 12:01 PM
HayJay's Avatar
Not sure I'd like it either. Haven't seen one in action, that's for sure.
HayJay is offline
HMBB
Powerquest
25
12-02-2007 09:33 AM
Downtown42
Fountain
40
12-16-2006 11:38 AM
Need-the-Speed
Fountain
22
12-24-2005 05:19 PM
Semper Fi
10-09-2004 08:08 AM
26scarab
03-14-2002 08:49 PM
