Leakdown test on a cold motor >
Old 10-03-2006 | 11:49 AM
onesickpantera's Avatar
Default Leakdown test on a cold motor
Can I do a leakdown test on a cold motor? The motor is out of the boat and I am unable to run it. Do you usually see higher numbers on a cold motor?
onesickpantera is offline
Old 10-03-2006 | 12:36 PM
Ted G's Avatar
Default Re: Leakdown test on a cold motor
Yes, leakdown past the rings will be higher, valves about the same. This would still be an indicator if one or two cylinders are markedly different.
www.cbpba.com
Ted G is offline
Old 10-03-2006 | 06:50 PM
Wobble's Avatar
SORE MEMBER
most of them are done cold anyway, no one checks a healthy motor.
Wobble is offline
Old 10-05-2006 | 11:36 AM
A cold leak down test on an engine that has been running is fine. Percentage of leakage will be higher. If the engine has set some time it is a good idea to warm the engine up to free up an crystaliztion on valve seats and such.
mrhorsepower1 is offline
Old 10-09-2006 | 03:56 PM
What would be an acceptable amount of leakdown on a cold 502??
dagah2x is offline
Old 10-09-2006 | 06:10 PM
How many hours are on it?
Old 10-09-2006 | 08:58 PM
About 100. I guess a better question would be how much difference would you see from a cold motor to a warm motor?
dagah2x is offline
ak
6
10-19-2008 12:33 PM
Toffen
1
12-04-2003 07:58 PM
THRILLSEEKER
9
03-06-2003 08:53 AM
26scarab
7
08-12-2002 02:25 AM
