42 Fountain vs. 382 Formula vs. 36 Baja >
Old 10-06-2006 | 12:51 PM
On Time's Avatar
Default 42 Fountain vs. 382 Formula vs. 36 Baja
I currently own a 2004 Baja 33 Outlaw with 496 HO's I am fairly happy with, but its not quite enough for the bigger water. I am considering decent buys on each of these boats. Give up your thoughts and comments please !!
On Time is offline
Old 10-06-2006 | 01:07 PM
Sea-Dated's Avatar
Default Re: 42 Fountain vs. 382 Formula vs. 36 Baja
If it is for bigger water, I would drop the Baja from the list. The Fountain and Formula are both great boats built for bigger water. I would go with the Fountain but I am a little biased. What power in the Fountain and Formula?
Sea-Dated is offline
Old 10-06-2006 | 01:10 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Define what kind of bigger water you want to run in. Ocean? LOTO? Lake Travis? What's your price range? What year of boat are you looking for? Are you looking for new or used?
Without knowing the specifics of each boat you have your eye on;
The 382 Formula will probably have the best ride.
The 42 Fountain will probably be the longest one per Reggie's ruler. ( )
The 36 Baja will run well, but might be be lower one on build quality.
Sydwayz is offline
Old 10-06-2006 | 01:16 PM
Only took one post for the Baja bashing to start, here we go
Considering Baja is a true Deep V with no steps, why wouldn't it be an option in bigger water? And considering netting out the transom and the beak, the Founatin 42 is really a 38 foot boat. You could probably go Outlaw 40 for cheaper than a 42 Fountain.
Thank you for being honest about your Fountain bias though, that is at least honorable, aside from the bashing of course I am biased towards Baja, as you can see.
Chris
chrisf is offline
Old 10-06-2006 | 01:25 PM
jryan26's Avatar
Bias aside, you see alot more people racing fountains and formulas. I dont know why no-one races bajas.
jryan26 is offline
Old 10-06-2006 | 01:29 PM
cosmic12's Avatar
from what I see you are talking 3 totaly different boats. in all respects. if we are talking bias I would have to say take a look at 37/43 Active Thunder. Brian I can;t believe you let that one slide
cosmic12 is offline
Old 10-06-2006 | 01:45 PM
On Time's Avatar
Here's more info:
2005 42 FTN staggered 525's
2004 382 Formula 525's
2004 36 Baja 500EFI's
Please comments on PERFORMANCE only price not the object
On Time is offline
Old 10-06-2006 | 01:54 PM
BajaRunner's Avatar
The Formula, And I own a 36 outlaw.
BajaRunner is offline
Old 10-06-2006 | 01:57 PM
cosmic12's Avatar
Originally Posted by avarady
Here's more info:
fastest to slowest just my2cts 42f/ 382FORM/ 36 Baja... ride 382/ 42/36 now do you care about cabin/freeboard/cockpit space/ storage/ quality of uoplstery/ resale and a bunch of other stuff???????
cosmic12 is offline
Old 10-06-2006 | 02:04 PM
Ted G's Avatar
Speed Fountain, Formula, Baja
Rough Stuff Formula, Fountain, Baja
Fit and Finish Formula, Fountain, Baja
Handling Baja, Formula, Fountain
www.cbpba.com
Ted G is offline
